Latest: bawward
Overall: 3614
Visitors: 206
Total: 206
03: Event Calendar
20: Home
52: Event Calendar
63: Event Calendar
75: Event Calendar
76: Event Calendar
87: Pictures
94: Event Calendar
103: Drivers
104: My Account
110: Event Calendar
116: Event Calendar
120: Event Calendar
124: Event Calendar
128: Event Calendar
158: Baja Forums
164: Event Calendar
170: Event Calendar
171: Baja Forums
178: Baja Forums
179: Baja Forums
184: Baja Forums
186: Event Calendar
189: Baja Forums
190: AMAZON.com
191: Baja Forums
192: Baja Forums
197: AMAZON.com
198: AMAZON.com
199: Home
200: Baja Forums
201: Baja Forums
202: AMAZON.com
204: AMAZON.com
205: AMAZON.com
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Bought me a donor car today...
Post Post subject: Bought me a donor car today...
Posted: Wed Mar 21, 2007 01:52 AM
Well, I went and bought a parts car today for my project. Found it on cl, it's a '68 baja with a 1600 sp, swingaxle. Been painted, runs/drives, has no interior or glass, no title. Has a chrome tri-mil exhaust, and a solex pict 30 carb.
I have a few questions though-
1) Are the heads the only difference between a single port and dual port? Can you change the heads to convert it?
2) The motor doesn't smoke at all that I can see, but it does push oil out the dipstick hole when running. Any ideas what could be causing that?
3) The intake manifold has a second, parallel tube that drops down by the exhaust on both sides, but isn't hooked to anything on either end. Is that tube connected to the intake, or is it just an exhaust crossover?
4) How do I tell if the front end is link pin or ball joint?
If I get a few minutes, I'll go grab some pics today or tomorrow. I'm probably going to start dismantling the thing pretty soon. Gonna have a complete front beam for sale (drum to drum), swingaxle trans (drum to drum), probably the exhaust, and eventually the pan.
Post Post subject: Re: Bought me a donor car today...
Posted: Wed Mar 21, 2007 02:22 AM
1, I read there are 2 studs that are shorter on a dual port at the top of the engine. (unconfirmed though, because the stud kits don't state s/p or d/p)
2, Usually it is blowby that creates excessive crankcase pressure. Can be a cheesy aftermarket breather, no breather, plugged breather or worn rings.
3, Intake manifold heater, usually blocked off or removed around here.
4, Most obvious way is ball joint upper shock tower curve out toward the wheels. Link pin are straight up and down.
Here is b/j www.chircoestore.com/c...5062f43f17
Here is l/p www.chircoestore.com/c...5062f43f17
Based on 68, should be b/j.
Hope this helps.
Posted: Wed Mar 21, 2007 02:29 AM
Is there a chance that the crankcase breather would be part of the oil fill cap? Because he's got a solid plug in the fill cap because he lost it. Where is the breather located?
Thanks DONT- I appreciate your responses!
Posted: Wed Mar 21, 2007 04:10 AM
The 2 top center studs are shorter for a dual port. If the car is a 68, it should be a balljoint unless somebody went through the hassle to change it..
Posted: Wed Mar 21, 2007 04:45 AM
AS FAR AS I KNOW YOU NEED CRANKCASE VENTALATION ON YOUR MOTOR , RIGHT WHERE YOU CAP IS SUPPOSE TO BE THERE SHOU BE A PLACE TO CONNECT A HOSE, JUST BELOW THE CAP. ON STOCK MOTOR & A PIC CARB THIS HOSE WOULD RUN UP TO AIR CLEANER TO BURN CRANKCASE FUMES THREW CARB, I JUST PUT A SMALL BREATHERON IT, WITH NO HOSE, BUT YOUR OIL OUT THE DIP IS MOST LIKELY CAUSED BY BLOWBY BECAUSE OF YOUR STYLE OF OIL CAP, AND YOUR VENT HOLE MIGHT BE PLUGGED BECAUSE OF IT.AND NO I,M NOT MAD ,THIS IS THE WAY I TYPE. LOOK MA ONLY ONE FINGER!
Posted: Wed Mar 21, 2007 06:05 AM
HEY JAMES! Just kiddin'. Thanks for the reply. I went out and looked, and this motor has no port under the oil filler to attach a hose. I can't find any semblance of a crankcase breather. The stand that the alternator sits on doubles as the oil filler- sound right?
Is there any way to check the VIN online and figure out the year of the pan? It starts with 1151, which is odd (if it's a '68), because my titled '65 pan starts with 1154.
Posted: Wed Mar 21, 2007 06:13 AM
The 68 will have 1 more digit in the VIN #
Posted: Wed Mar 21, 2007 06:29 AM
YES IT DOUBLES,DO YOU HAVE STOCK OIL FILLER(TIN) OR AFTERMARKET, ALUM?THE STOCK ONE HAD BREATHER PORT RIGHT IN THE TIN ON TOP RIGHT NEXT TO THE OIL FILL CAP, IF YOU HAVE A AFTERMARKET OIL FILLER YOU MIGHT HAVE TO TAP ONE IN. JUST BELOW CAP (PARTWAYDOWN FILLER NECK, OR INTO YOUR VALVE COVERS,I THINK THE OIL NECK WOULD BE EASYER.SCREW IN A HOSE CONNECTER(BRASS) THEN GO TO AUTO STORE AND PICK UP A OIL BREATHER OUT OF A CHEVY VALVE COVER THEY MOUNT WITH A SMALL HOSE CLAMP. THEY LOOK NICE AND ARE SIMPLE AND CLEAN MOST HAVE CLEANABLE FILTER. WHAT DO YOU THINK GUYS. DOES HE NEED SOME VENTING??? AND PLLLEEEAAASE!!!!call me jim
Posted: Wed Mar 21, 2007 06:33 AM
Well then, this pan must be older than '68. Plus it's linkpin and not balljoint.
Posted: Wed Mar 21, 2007 06:34 AM
I JUST USE JAMESR6168 BECAUSE I,VE USED IT FOR EBAY FOR MANY YEARS, SO IT WAS EASY TO REMEMBER. THATS MY REAL NAME BUT MY FRIENDS JUST CALL ME JIM. (TO MY FACE ANYWAY!!) I WISH I COULD CHANGE IT AND KEEP MY RANK BUT I DO,NT KNOW IF THATS POSSABLE!
Posted: Wed Mar 21, 2007 04:34 PM
Here are the parts for a complete breather system.
filler neck www.chircoestore.com/c...42faceca98
breather www.chircoestore.com/c...42faceca98
Then mount nipples on the top of your valve covers, www.chircoestore.com/c...42faceca98
run hoses from v/c to upper fittings on breather, then the drain to the filler neck.
If you want quick and cheaper and have the right air cleaner, mount a hose from the filler to the air filter, or clamp on a small breather like Jim said, but then the oil mist the escapes will still coat your engine.
Posted: Wed Mar 21, 2007 11:37 PM
Here's a pic of the filler neck. Now that I removed the plug, I see that it's threaded. Thanks again to DONT for his prompt replies.
Posted: Wed Mar 21, 2007 11:39 PM
Oh- and I know you're going to give me a hard time about that wire hanging there doing nothing. I'm going to remove it- today, after I cleaned up the motor, I accidentally pushed that connector against the alternator, and it's HOT! It goes to the starter solenoid. Anyone have any idea why this wire would be run back to the carb area and then not connected to anything???
C/ANDREW
C/ANDREW
Posted: Wed Mar 21, 2007 11:55 PM
hey az350, if you don't mind I was just wondering how much you paid for you bug. I was considering buying one from craigs list also. if you don't wanna share thats ok
Posted: Thu Mar 22, 2007 04:21 AM
YOUR MISSING THE PCS THAT MOUNT ON THE OIL FILLER ,CALL CHIRCO AND THEY WILL SELL YOU THE PC. OR PULL STOCK ONE FROM A DIFFERENT MOTOR OR MAYBE SOME ONE ON SITE HAS A OLD ONE, BUT YOU ARE MISSING A PC.
1569 mufasavnvmc 1196631 Re: what did you do to...
 Sat May 11, 2019 07:20 PM
No new posts VW Volkswagen & Baja Bug General Discussion Had to go play in the rain today! 3 azdesertrat87 3442 Re: Had to go play in ...
No new posts VW Volkswagen & Baja Bug General Discussion TODAY TODAY TODAY ONLY!!!!!! 2 wideopenmotorsports 2695 TODAY TODAY TODAY ONLY...
 Wed Jul 09, 2014 05:02 PM
No new posts Projects and Builds bought a turd…. better get out the polish!
been a while...
7 acousticrawk 7742 bought a turd…. bett...
 Sun Jun 22, 2014 11:44 AM
No new posts VW Volkswagen & Baja Bug General Discussion Went for a dirt road cruise today 6 crestfallen 6862 Went for a dirt road c...
 Sat Apr 28, 2012 05:27 PM
crestfallen View latest post
