Visitors: 67
Total: 67
11: Event Calendar
15: Event Calendar
24: Event Calendar
34: Pictures
56: Pictures
61: My Account
62: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- 3rd clutch cable broke in less then 6 months
milleraj119
milleraj119
Post Post subject: 3rd clutch cable broke in less then 6 months
Posted: Tue May 15, 2007 05:43 AM
3rd clutch cable broke in less then 6 months i have no idea why its a 68 bus trans in a baja cluch randomly just snapd first one the cable part broke second the pully on the clutch peadal proke 3rd cable snapped agian i have a stock pedal assembaly with the roller gas pedal style can anyone direct me into some information to why or stop it from doin in agian i was wondering if also if anyone can gice me some links on were to get a hydrolic clutch and a link on how to set it up thanks.
Post Post subject: Re: 3rd clutch cable broke in less then 6 months
Posted: Tue May 15, 2007 05:46 AM
were is the location it brakes? That is were you will find the problem. somthing sharp rubbing or to steep an angle
milleraj119
milleraj119
Posted: Tue May 15, 2007 05:51 AM
already looked nothin sharp proke right were it connects to the metal loop that goes on the clutch pedal what do u mean a to steep of an angle
Posted: Tue May 15, 2007 07:45 AM
Do you have a real heavy pressure plate?
Posted: Tue May 15, 2007 12:26 PM
So the cable brakes at the end? Is this a custom cable that you made or do you have the metal end on the cable with the big wing nut?
milleraj119
milleraj119
Posted: Tue May 15, 2007 05:15 PM
no not sure if the pressure plate has a lot of pressure how would u find out wihout puling the motor
sickbaja68
sickbaja68
Posted: Thu May 17, 2007 10:42 PM
You can't find out if the pressure plate has pressure on it without pulling out the motor and pulling off the pressure plate and stepping on it to check the pressure in the middle. Sounds like it might be that the bowden tube has too much angle in it. Meaning that it bends up too much. Readjust it and take your old cable and check it against a new one to see if it is the right length for your year. Also, get a better bowden tube. Not a plastic ended one that is cheap and can break. The bowden tube is by your wingnut adjuster for the clutch to the left of the tranny underneath. Hope this helps.
2180 Baja bug with 091 trans.
11 51BUG50 2474 Clutch and pressure pl...
 Fri Mar 10, 2017 07:22 PM
parts
0 bajablastman1214 1429 Clutch
 Sun Aug 16, 2015 05:23 AM
No new posts VW Volkswagen & Baja Bug General Discussion sticking accelerator cable 11 65bajabug 3821 Re: sticking accelerat...
 Wed Mar 13, 2013 12:29 AM
nshoe18 View latest post
Really bad issues
4 Pointvirus 2114 Clutch Issues
 Mon Dec 03, 2012 06:33 PM
No new posts VW Volkswagen & Baja Bug General Discussion where to find clutch slave install tips/instr.??? 6 bajabuggin 4999 where to find clutch s...
 Sat Sep 11, 2010 02:58 PM
az350x View latest post
