Visitors: 170
Total: 170
26: Event Calendar
41: My Account
71: News Letter
108: Pictures
154: Baja Forums
157: Pictures
158: Event Calendar
168: Baja Forums
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- electirc fuel pump
electirc fuel pump
wazhier
wazhier
Post Post subject: electirc fuel pump
Posted: Thu Sep 27, 2007 03:04 AM
my fuel pump is making a loud ticking noise when it is on. should it make any noise? its so loud i can hear it over the motor running. its still working. is this a sign its going to crap out on me?
thanx ryan
Post Post subject: Re: electirc fuel pump
Posted: Thu Sep 27, 2007 03:08 AM
Does it look like a block? if so then yes it's a good thing. if the clicking stops then it's a bad thing. It's a vibrator pump.
Your best bet is to upgrade to a holley type fuel pump as the vibrator pumps seem to last only 2 years.
Posted: Thu Sep 27, 2007 05:48 AM
I can get you a pro comp blue pump with regulator for $70. They are an exact copy of the holley blue.
Posted: Thu Sep 27, 2007 07:41 AM
can you get them ith the built in regulator too?
www.holley.com/12-801-1.asp
Flows 71 GPH at 4 PSI
Regulator is not required
this is the one I use, it's a nice pump and this type should work well in your baja. Like "D" said he probably can get the like pump from pro comp
Posted: Thu Sep 27, 2007 03:37 PM
Well technically the 12-801 holley doesnt have a built in regulator, it just has a pressure limit spring that drops it to 7lbs not 4lbs, and you may still need a regulator for some carbs (some carbs can only take 3psi at the needle and seat).
But Yes I can get the pro comp 2801 equivelant to the holley red pump, They are $59.
PROCOMP "RED"
Flows 115 GPH (free flow
Pressure is pre-set at 7 PSI
Regulator not required for most applications
PROCOMP "BLUE"
Flows 130 GPH (free flow)
Pressure is pre-set at 14 PSI
Fuel Pressure regulator is required
PROCOMP "BLACK"
Compatible with alcohol or methanol fuels
Flows 140 GPH (free flow)
Pressure is pre-set at 9 PSI
Posted: Thu Sep 27, 2007 05:34 PM
this was right from the Holley web site It was cute and paste. bet yes no regultor.
Posted: Thu Sep 27, 2007 06:33 PM
If you read the complete specs, it says maximum pressure 7PSI, and this can fluxuate from 4 to 7 psi. The 4 psi is at free flow, no way you can get free flow through a 1/4 (typical vw), 5/16, or 3/8 line, you need a 1/2 line for that. When you restrict flow it increases pressure and then you can run into problems. You wont have any issues on your car because you run a holley carb and the needle and seats will hold 7psi all day, but some of the other carbs will only handle 2.5-3 psi.
Posted: Thu Sep 27, 2007 07:02 PM
"you run a holley carb and the needle and seats will hold 7psi all day" Smile Not true at this time after the car was sitting all summer the needle has dried up, deformed or got stuck in the Holley. Need to pull the carb off and see what is going on. car only runs now when it's floored and gives you a huge black smoke cloud that would make any cummings owner proud. Shut the pump off and the car runs like normal on what is left in the fuel bowls.
No new posts VW Volkswagen & Baja Bug General Discussion rack & pinion w/stock fuel tank 0 ghettodish 1958 rack & pinion w/stock ...
 Wed Nov 09, 2011 06:44 AM
ghettodish View latest post
Replacement Possible or Not
3 jemizasi 3765 1966 VW Beetle Fuel Se...
 Fri Apr 29, 2011 05:51 AM
No new posts VW Volkswagen & Baja Bug General Discussion In & Out Oil Pump 0 wideopenmotorsports 1701 In & Out Oil Pump
 Wed Mar 23, 2011 03:03 AM
No new posts VW Volkswagen & Baja Bug General Discussion Fuel pump failure 2 chickenpants 2067 Re: Fuel pump failure
 Mon Nov 02, 2009 06:57 PM
chickenpants View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Fuel Filler Ideas? 4 catchbats 6563 Fuel Filler Ideas?
 Sat Jul 11, 2009 09:04 AM
57baja View latest post
