Visitors: 99
Total: 99
37: Event Calendar
39: Event Calendar
42: Event Calendar
44: Event Calendar
50: Event Calendar
63: Event Calendar
71: Event Calendar
73: Event Calendar
75: Event Calendar
84: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Steering question...
r8rfan66
r8rfan66
Post Post subject: Steering question...
Posted: Thu Jan 10, 2008 05:00 AM
I've been working on a body off baja for just about a year now. I purchased a rolling pan from someone awhile back. It was a 62 that had been converted to ball joint beam for some reason. Anyhow, I had a Thing beam in my garage so I bought it.
Today, I was installing the body back onto the pan and ran into some problems. The forward body mounts were resting on the beam fine, but the body wouldn't seat on the "hump" in front of the pedals. I cut off the forward body mounts and the body seated beautifully!
After whistling zippity doo-dah day out my rear-end while happily bolting down ALL the body bolts, I find out my steering shaft wont align with the steering coupler. The shaft is about 1/2" lower and cant be raised enough to be mated together.
Do you guys know if a u-shaft off of a 71 will do the trick? Do you know if the diameter of the shaft on my 62 is the same as a 71? I know I may have to do some fab, but lookin for some ideas.
Sorry for the novel......Thanks!!!
Post Post subject: Re: Steering question...
Posted: Thu Jan 10, 2008 05:06 AM
The shaft diameter is the same on all of the bugs I have ever messed with. If you go with universal joints, you will need to put a bearing i the lower part of the column. You can use an upper bearing from a 66 & earlier and it will work fine.
r8rfan66
r8rfan66
Posted: Thu Jan 10, 2008 05:17 AM
Does this bearing press into the bottom of the column?
Thanks for the quick reply Bugzyla! I've been trying to figure out how to fix this for hours....
Crash
Crash
Posted: Thu Jan 10, 2008 05:27 AM
You might just need to rotate your steering box on the beam to get it to line up. If someone changed to a balljoint on a '62 pan (can't imagine why) then it may be misaligned or they rotated the box to line it up for what they were using it for. If the beam came out of a thing the box is angled up to line up with the higher steering wheel.
-Mark
Mark Johnson
Blind Chicken Racing
www.blindchickenracing.com
No new posts Projects and Builds Cheap DIY electric power steering
16 Azdrtdog 9320 Cheap DIY electric pow...
 Fri Nov 06, 2015 01:07 AM
No new posts VW Volkswagen & Baja Bug General Discussion Baja Bug Modification question 4 Ailill 8097 Baja Bug Modification ...
 Mon Apr 13, 2015 04:07 AM
Ailill View latest post
No new posts VW Volkswagen & Baja Bug General Discussion looking for shocks and steering dampner 2 Rigger 1713 looking for shocks and...
 Tue May 13, 2014 12:30 PM
No new posts VW Volkswagen & Baja Bug General Discussion Question about local vendors in the Phoenix Valley areas 2 Salvo 2728 Question about local v...
 Fri Sep 20, 2013 07:37 AM
Sweetjumps View latest post
No new posts VW Volkswagen & Baja Bug General Discussion homade baja fenders question 9 vtbaja 5529 Re: homade baja fender...
 Mon Sep 16, 2013 06:23 PM
