Latest: Milkmanbryan
Overall: 3583
Visitors: 115
Total: 115
11: Event Calendar
16: Event Calendar
25: Home
103: Pictures
115: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Rear Fenders..?
Rear Fenders..?
BajaChick21
BajaChick21
Post Post subject: Rear Fenders..?
Posted: Mon Mar 10, 2008 09:46 AM
Soooo... Before I do something completely STOOPID!
Can I cut fiberglass??? Or should i sand it.??
I want to re-shape my rear fenders. But I dont want to crack them sooo what can i doo? I was thinking i can use my dremel on a low setting? has any dont this before>??
I can do Everything a man can do but better!
except for being able to pee standing up I'll leave that to you guys.. =(
Post Post subject: Re: Rear Fenders..?
Posted: Mon Mar 10, 2008 10:43 AM
jig/skill saw with a fiber glass blade works just fine, or a 32 tooth metal blade
BajaChick21
BajaChick21
Posted: Mon Mar 10, 2008 10:48 AM
okey dokey
Posted: Mon Mar 10, 2008 03:35 PM
Also run masking tape over the front and back side before you cut. this will keep the fiber glss from chipping and give you a clean cut
BajaChick21
BajaChick21
Posted: Mon Mar 10, 2008 08:29 PM
Yeah I was going to do that any way So i know where to cut and so i can find my shape.
Posted: Mon Mar 10, 2008 09:19 PM
I have a wheel for my Dremel that I used to cut my fenders, and it worked AWESOME. I bought it originally to cut formica sheeting.
Wear a respirator or something though- what a dusty MESS it makes!
Billy
Billy
Posted: Tue Mar 11, 2008 01:49 AM
I had to use self tapping bolts to get some of my back fender on. The smell was bad!!! hahaha
nukeworker
nukeworker
Posted: Tue Mar 11, 2008 05:13 AM
I used a RotoZip to cut the headlight holes. Works good. Practiced on wood first.
twistedsmily
twistedsmily
Posted: Tue Mar 11, 2008 03:50 PM
dont forget safty glasses or other glasses that shit will kill your eyes <been there done that
Posted: Wed Mar 12, 2008 04:42 AM
Oh yeah- forgot about that part. I got some in my eyes too when I did that. Hurt so bad for so long it kinda scared the crap outta me! Use GOGGLES or something that gives you full protection. Shocked
Posted: Wed Mar 12, 2008 08:44 AM
Just don't use a cutting torch!
I've done about all of the above and they all work. Wear long sleeves, too. Fiberglass dust is itchy stuff and it'll drive you nuts.
oldfart
oldfart
Posted: Wed Mar 12, 2008 08:56 PM
if it weren't for ladies present, I'd recount when I poured metal prep all over my crotch. that made fiberglass dust in my eyes a cake walk.
anyhow, when you cut them, are you going to reinforce the edge with anything?
Posted: Thu Mar 13, 2008 03:44 AM
I MADE A 'L' BRACKET FROM THE FENDER BODY BOLT TO THE EDGE OF THE FENDER,, THEN TWO BOLTS IN THE FIBERGLASS,,LAST BODY BOLT TO THE REAR,WIDEST PART OF FENDER,,WORKED GREAT,,PROBABLY STONGER THAN UNCUT FENDER!!
oldfart
oldfart
Posted: Thu Mar 13, 2008 06:42 PM
I've seen elec. conduit bent to follow countour and glassed over. Or you could use wood, cardboard, just about anything. The strength comes from the fiberglass applied over the part, bonding it to the fender. heck, even use what you cut off, rough the smooth side up, put resin on it, apply and glass over it, clamp till dry. Or instead of clamping, screw 2 pieces together, then remove and fill holes when set up.
BajaChick21
BajaChick21
Posted: Sat Mar 15, 2008 10:05 AM
UGH! OKay I BURNED OUT MY BRAND SPANKEN NEW DREMEL I GOT FOR X_MAS>... =( I'm sad.
No new posts VW Volkswagen & Baja Bug General Discussion Max angle for rear axles 5 Wattsd 3587 Re: Max angle for rear...
 Fri Jan 29, 2016 04:03 AM
Wattsd View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Rear Rim Backspacing 1 LittleBaja 2255 Rear Rim Backspacing
 Fri Nov 06, 2015 03:13 AM
JWHracing View latest post
what do you use
4 bdrdunes 2813 Baja bug rear led ligh...
 Thu Dec 18, 2014 02:55 AM
No new posts VW Volkswagen & Baja Bug General Discussion homade baja fenders question 9 vtbaja 5338 Re: homade baja fender...
 Mon Sep 16, 2013 06:23 PM
No new posts Projects and Builds Possible rear seat?? 4 TattooedIrish 4128 Possible rear seat??
 Thu Aug 30, 2012 08:55 AM
Rigger View latest post
