Visitors: 110
Total: 110
03: Event Calendar
06: Pictures
07: Event Calendar
12: Event Calendar
24: Event Calendar
40: Event Calendar
44: Event Calendar
54: Event Calendar
58: Event Calendar
59: Event Calendar
62: Event Calendar
64: Event Calendar
68: Event Calendar
74: Event Calendar
75: Event Calendar
78: Event Calendar
82: Event Calendar
86: Event Calendar
87: Home
95: Event Calendar
96: Event Calendar
98: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- TURBO
TURBO
Post Post subject: TURBO
Posted: Sun Mar 16, 2008 09:30 PM
anybody know if this is a good buy or not ?
cgi.ebay.com/ebaymotor...0213011711
or this one...
cgi.ebay.com/ebaymotor...0219645972
Post Post subject: Re: TURBO
Posted: Sun Mar 16, 2008 10:56 PM
Shocked I wish that I new more about them!! Seems cheep!
Posted: Mon Mar 17, 2008 12:19 AM
Its about the going rate. Check out craigslist and buy a used one for $25- $50 and then take it to turbo and tractor in phoenix and have it gone through. They usually charge $100 -$150 to go through it and then you know its freash and ready to go, and they stand behind it.
Posted: Mon Mar 17, 2008 04:17 AM
forgot to say, this will be going on a 22r rail.....
ditch68
ditch68
Posted: Mon Mar 17, 2008 04:52 AM
Is that yours?
Nice - my brother has an '83 SR% 4WD truck with a 22r....that is one good motor.
My baja would have had a turbo with it for an extra $500. But I figured I didn't know much about the condition, etc. and the extra 500 went a long way toward making the car more to my liking.
But someday, I will not rule out a turbo. Easy HP.
Jeff
Beer is NOT AN OPTION....
(meaning not optional)
1971 Type 3 Squareback FI/AT
madman74
madman74
Posted: Mon Mar 17, 2008 06:05 AM
Those are chinese turbos and are good for parts for building a real turbo. The bearings /thrust bearings are not very good. The turbine is not of the best material either. If It was me and I was looking for a good turbo that would pull well on a 2500cc motot I would look at a stock turbo for a 2.3 83-86 turbocoupes and svo And 85-89 merkur xr4ti this turbo will handle 300 hp. Should mkae full boost around 2800 rpm on a 22r maybe a little sooner if you use a .48 exhaust housing. If ou are looking for a quick spooling turbo and dont need more than 240hp the IHI from a 87-88 ford turbocoupe would be a good choice, it should have full boost around 1800-2000 rpm and will have better throttle response than the bigger t-3s. with the chinese turbo you would probably see full boost around 3500-4000. I also notice you have a pretty good quality header. You could just run an elbow off of your current header with a t-3 style flange. It should work just fine, might not look the best.
Oops it broke!
Posted: Tue Mar 18, 2008 01:23 AM
are the t-bird turbos readily available at junk yards ?
what other options do i have for a exhaust manifold other than scabbing on to my existing header ?
i did read somewhere about making one out of pipe, not tubing....
madman74
madman74
Posted: Tue Mar 18, 2008 02:58 AM
well if you want to buy on that only requuires a little work this place is it. www.jgstools.com/turbo/thk.html
But Its easy enough to make it yourself if you geta header flange, a t-3 flange and some weld els from a plumming shop.
Oops it broke!
No new posts VW Volkswagen & Baja Bug General Discussion baja / turbo / turning breaks,
info needed.
11 Jc26 8375 baja / turbo / turning...
 Tue Jul 19, 2011 04:38 PM
Jc26 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Mazda 13b Turbo Conversion 2 logan44 3761 Mazda 13b Turbo Conver...
 Tue Jun 21, 2011 09:00 PM
HuggingxCorners View latest post
No new posts VW Volkswagen & Baja Bug General Discussion turbo efi baja
30 Neander 17349 Re: turbo efi baja
 Thu Dec 04, 2008 05:20 AM
Neander View latest post
No new posts VW Volkswagen & Baja Bug General Discussion 1776, 1835 or 1600 w/ turbo 2 nube_w_1970baja 2108 Re: 1776, 1835 or 1600...
 Mon Oct 27, 2008 08:10 AM
Thuff View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Duck tail versus Turbo tail 9 Billy 7490 Re: Duck tail versus T...
 Tue May 20, 2008 07:55 AM
WaBaja View latest post
