Latest: rcwtony
Overall: 3607
Visitors: 120
Total: 120
08: Garage
16: Event Calendar
18: Event Calendar
32: Event Calendar
51: Event Calendar
80: Event Calendar
81: Event Calendar
90: Event Calendar
94: Event Calendar
96: Event Calendar
118: Home
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- NEED HELP ASAP!!! Going to ASVAB TEST
nube_w_1970baja
nube_w_1970baja
Post Post subject: NEED HELP ASAP!!! Going to ASVAB TEST
Posted: Wed Nov 12, 2008 08:12 PM
i'm going out to take my ASVAB test this afternoon in central phx.
the problem i'm having is at 1/4 throtle the car wants to bog down and die. this happens in all gears (which makes it hard to get up to speed...) and also when idleing.
rebuilt the carb a few weeks ago and everything was running well.
last night is when this started...
not sure what i need to fix, but i need help on getting it figured out. it is my only car!
if anyone knows anything, try to call me 480-338-2714.
not sure if it's the air-fuel mixture, gas pump, diaphragm, vacuum leak.
PLEASE!!PLEASE!!PLEASE!!
ridinthedunes
ridinthedunes
Post Post subject: Re: NEED HELP ASAP!!! Going to ASVAB TEST
Posted: Wed Nov 12, 2008 08:47 PM
Is it doing it at steady 1/4 throttle or just when you push the gas?
Does it ever clear up if you leave it at 1/4 throttle?
Posted: Wed Nov 12, 2008 08:48 PM
idle jet clogged?
Posted: Fri Nov 14, 2008 03:58 AM
Did you get her running yesterday? I read your post shortly after you put it up, but having nothing to contribute, I decided to not get your hopes up with a topic reply email...
How was the ASVAB? I remember taking that thing...
nube_w_1970baja
nube_w_1970baja
Posted: Fri Nov 14, 2008 07:39 AM
talked to the son of the sailor of a guy's friend that knew the guy that used to have the VW shop off i-17 with the blue VW on top of the sign at 33 ave something or other, while i was painting curbs today.
actually the guy claimed to be the actual son of the owner that used to be there a few years ago. he said, "check the valves 1-2-3-4 in that order. after that, pull the wires one at a time to find out if it's getting spark properly, pull the plug and check compression, check gap on the points, retighten head bolts. to start things off of course..."
so i guess i have some work to do this weekend
oh, the ASVAB score was 69, recruiter said i'm pretty good. but, hard to predict the future.
not sure if idle jet is clogged.
at 1/4 throttle motor bogs down, but eventually clears up as the wid pushes me or i can draft behind a semi or i start going downhill...
ridinthedunes
ridinthedunes
Posted: Fri Nov 14, 2008 08:13 AM
what carb (s) are you running?
Might be your excelerator pump....
Does it run good other than that...idle fine?
Does it do it just under a load or when you're in the back dry reving it too?
nube_w_1970baja
nube_w_1970baja
Posted: Sat Nov 15, 2008 02:04 AM
34-pict3
just rebuilt the carb, new accelerator pump dia...
yeah everything runs good just not above idle, after the revs get up, everything gets better.
and today for some reason it was running great, no backfires, decent power, didn't have to draft behind a semi. i think the universe is f&^%ing with me...
it bogs down while dry revving and under load, except for today, might hold of until sunday to do anything...
ridinthedunes
ridinthedunes
Posted: Sat Nov 15, 2008 02:21 AM
With the car just sitting there, not running, take off the aircleaner and pump the gas and see if you're getting a good squirt in the carb. with every pump...should have almost no play before the squirt after pumping the throttle
Posted: Sat Nov 15, 2008 09:24 AM
sorry nube,,family forum you cant say F&^*ING on here,, but you can spell it like i did ok? or some other way just cant come out and spell it,,,,thanks,,,jim
nube_w_1970baja
nube_w_1970baja
Posted: Sat Nov 15, 2008 09:35 PM
sorry about that, i never did read all the rules, but it won't happen again
Posted: Sat Nov 15, 2008 11:36 PM
Very Happy thanks np
ridinthedunes
ridinthedunes
Posted: Sun Nov 16, 2008 02:59 AM
any luck with the car?
Don't feel bad...I been on this forum for a long while and didn't know you couldn't swear either Embarassed Luckily for me...I never did anyways Smile
Posted: Sun Nov 16, 2008 03:34 AM
Laughing
nube_w_1970baja
nube_w_1970baja
Posted: Sun Nov 16, 2008 05:48 AM
luckily things have been going pretty good yesterday and today. i think it was the cold weather and humity level, so i think i'll be posting something pretty soon about how to adjust for temp and humidity...
nube_w_1970baja
nube_w_1970baja
Posted: Wed Nov 19, 2008 01:39 AM
so things were so bad yesterday, i pulled over on the 101 and broke out the bentleys and read over the distributor section. sunday night we pulled the dissy to replace the oil seal. i guess i should check the points on a weekly basis. regapped them and now it runs like a dream come true.
never ran better. i can finally go faster than 50mph.
No new posts VW Volkswagen & Baja Bug General Discussion Felix Baumgartner test drives the Volkswagen XL1 0 trev0006 3217 Felix Baumgartner test...
 Fri Mar 08, 2013 07:37 AM
No new posts VW Volkswagen & Baja Bug General Discussion needed asap swing axle trans 5 Dirtjunkie 3388 needed asap swing axle...
 Fri Oct 12, 2012 06:10 AM
No new posts VW Volkswagen & Baja Bug General Discussion !st mini test drive 6 Brettucks 3523 Re: !st mini test driv...
 Sat Mar 06, 2010 05:25 AM
Preston View latest post
No new posts VW Volkswagen & Baja Bug General Discussion They do it every time. (Rails for sale test) 12 perrib 11183 Re: They do it every t...
 Sat Nov 14, 2009 11:12 PM
No new posts VW Volkswagen & Baja Bug General Discussion JWH Racing trailing arm beta test. 5 perrib 5102 JWH Racing trailing ar...
 Fri Jul 31, 2009 06:19 PM
DONT View latest post
