Visitors: 139
Total: 139
21: Event Calendar
23: Pictures
24: Event Calendar
29: Event Calendar
31: Event Calendar
37: Event Calendar
54: Event Calendar
55: Event Calendar
65: Pictures
77: Pictures
79: Event Calendar
97: Pictures
101: Event Calendar
122: Event Calendar
127: Event Calendar
133: Event Calendar
137: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- tuning recommendations help!
Neander
Neander
Post Post subject: tuning recommendations help!
Posted: Wed Oct 28, 2009 02:33 AM
hey so ive got a 1641cc that needs a good tuning. the specs are: 1641cc, 31pict carb, single port, carb main jet .5 larger, engle w100 cam. rite now i have the timing at 30 degrees. the engine stumbles on acceleration and it just now backfired when i punched the gas a little while i was driving. i was wondering what i should set the timing, valve gap, and point gap to. thx!
Nander out
vwbill
vwbill
Post Post subject: Re: tuning recommendations help!
Posted: Wed Oct 28, 2009 02:52 AM
I also have a W100 cam. Card says all valves should gap at 0.004"
Neander
Neander
Posted: Wed Oct 28, 2009 02:55 AM
cool thx thats a start. yea i didnt install the cam so i dnt have the card or know anything about it.
Neander
Neander
Posted: Wed Oct 28, 2009 02:56 AM
whats your timing at?
kyle_pc_75
kyle_pc_75
Posted: Wed Oct 28, 2009 04:44 AM
What distributor? Probably 28-30 at max advance is good.
Kyle
Neander
Neander
Posted: Wed Oct 28, 2009 06:21 AM
ive got a 009 dizzy. yea my timings at 30 last time i checked
Posted: Wed Oct 28, 2009 02:39 PM
Check out this tech tip. It works I have done it. Sometimes it doesnt remove the hesitation all the way but it will help.
www.airsupplyvw.co.uk/...th009.html
Posted: Wed Oct 28, 2009 07:43 PM
Find a good used later model vaccum/ mechanical advance distributor you get better acceleration, better fuel mileage and it will retard under a load.
The .002 difference in valve lash won't matter.
Points adjusted correctly and tight distributor shaft?
Is you pre heat functional?
Is the acc. dump tube in place and adjusted?
Does the acc pump squirt fuel as soon as the throttle is cracked and keep spraying.
Neander
Neander
Posted: Thu Oct 29, 2009 07:58 PM
i will check my points. what should they be at? my pre heat tube is disconnected because of my tri-mil exhaust. the acc.pump could also be a bigger factor with this im sure it needs adjustment.
Posted: Thu Oct 29, 2009 08:21 PM
.015" for the point gap. You need to add the preheat to the Trimill. Trying to tune it at any temp under 100 degrees outside without preheat is a waste of time. The heat keeps the fuel atomized as it travels through the long intake runners. Once it gets cool outside the intake will ice up.
Neander
Neander
Posted: Thu Oct 29, 2009 09:08 PM
yea i noticed that wen i drive it at nite when its cold outside it runs like sh**
No new posts VW Volkswagen & Baja Bug General Discussion tubing notcher recommendations 13 chrispy56 7089 tubing notcher recomme...
 Tue Apr 03, 2012 06:31 PM
brokenparts View latest post
No new posts VW Volkswagen & Baja Bug General Discussion What is a good shop to bring for tuning? 6 Sample 2681 Re: What is a good sho...
 Fri Feb 01, 2008 04:45 PM
No new posts VW Volkswagen & Baja Bug General Discussion after some fine tuning... 1 shpuz 1460 Re: after some fine tu...
 Tue Jan 29, 2008 02:57 AM
joxracing View latest post
