Latest: bawward
Overall: 3614
Visitors: 208
Total: 208
16: Home
18: Contact Admin
19: Event Calendar
21: Event Calendar
59: Event Calendar
81: Event Calendar
100: Event Calendar
103: Event Calendar
121: Event Calendar
124: Event Calendar
131: Event Calendar
139: Event Calendar
145: My Account
151: Drivers
152: Event Calendar
158: Event Calendar
159: Event Calendar
164: Event Calendar
183: Baja Forums
189: Baja Forums
190: AMAZON.com
196: Event Calendar
197: AMAZON.com
198: AMAZON.com
202: AMAZON.com
203: Baja Forums
204: AMAZON.com
205: AMAZON.com
207: AMAZON.com
208: Baja Forums
Baja Forums -:- AzBaja.com Members -:- Projects and Builds -:- My Blue Baja Build...
Blake22211
Blake22211
Post Post subject: My Blue Baja Build...
Posted: Wed Oct 28, 2009 06:00 PM
Well, time for a new car and I went to pick up a 1968 Baja Bug. Car looked great, ran so-so (due to old gas and a need of an oil change). Interior is nice.
Here are some pictures from when I bought it...
Since these pictures I have a rear engine cage, got a rear view mirror in there, replaced a few loose bolts, etc...
Getting new racing seats and 3 point seat-belts in on Friday... Wink
What's you guys' opinion on VW Paradise in San Marcos? That's who I'm having my seats installed by...
How hard is it to remove the stock seat rails from the pan?
Straights are for fast cars...Turns are for fast drivers...
My Garage Link!
Post Post subject: Re: My Blue Baja Build...
Posted: Wed Oct 28, 2009 07:34 PM
My fingers get tired clicking on photo links. Next time try to copy and paste the img coding. Smile
Since VW Paradise has the fasted VW powered dragster they should be able to get your seats securely installed.
You can just leave the seat tracks in. There are a lot of spot welds to drill out.
Blake22211
Blake22211
Posted: Wed Oct 28, 2009 10:18 PM
Fixed it Smile
Okay, because they told me they would most likely need to remove the old seat rails to install my brackets...and it will be another 1-2 hours of $80/hr to do it!! Is that a bunch of crap?
Here are the mounts I have...
www.chircoestore.com/c...ts_id=2083
My Garage Link!
kyle_pc_75
kyle_pc_75
Posted: Thu Oct 29, 2009 12:20 AM
Good looking car!
Seat rails...just cut 'em out and grind 'em down with a 4 1/2" grinder. That's what I did, took me about half an hour. In fact, installing your own seats is pretty easy, especially since you have pre-made brackets.
Kyle
Posted: Thu Oct 29, 2009 01:07 AM
The floor should be reinforced if the seats are getting bolted to the floor. I was thinking they were welding in tubing to the tunnel and heater channels to attach the seats. Two hours to cut them out with a cut off wheel or torch is a little much. If you drill them out and weld up the holes two hours is about right. If your just going to have them bolted in you can do that yourself.
Blake22211
Blake22211
Posted: Thu Oct 29, 2009 05:20 AM
kyle_pc_75 wrote:
Good looking car!
Kyle
Thanks!
I would grind them out. but I don't want to burn up all the new carpet Sad
Yeah...How do I drill holes and mount the seats?
Either way I'm going down there, I need seatbelts installed, and you have to take the rear quarter window out and remove part of the pillar to do that...
My Garage Link!
Blake22211
Blake22211
Posted: Thu Oct 29, 2009 05:46 AM
Okay so here is my idea...
I just cut the sections out of the old rails that the seat mounts need to fit in...
Then drill through to the other side and put big pieces of aluminum or some type of metal to keep the bolt from coming through....?
Here is a little picture I drew to show what I'm thinking of doing...
What do you guys think?
My Garage Link!
Posted: Thu Oct 29, 2009 10:45 PM
It should work.
Blake22211
Blake22211
Posted: Fri Oct 30, 2009 07:33 AM
Okay great. I got the seat-belts in today. Only hard part was cutting a hole in the carpet box that the previous owner installed so that the retractors would fit...
I may have a problem though...The car lets out smoke puffs when I let off the gas and shift. Seems to be all white smoke, which means its running rich right?
I know if it is blue then it's burning oil...
and I checked the oil after driving it today, it was lower than a couple days ago when I checked it. It may be the leak in the dipstick piece. It leaves a few drops wherever I park. but not enough to move it a half an inch on the dipstick...
So am I burning oil? if so, what do I need to do to fix that?(I'm kinda dreading the answer to that question lol)
More Updates!..........................
-Installing an electronic ignition
-Rebuilding the carb
-Adjusting the valves
-Adjusting the timing
-Replacing spark plugs
My Garage Link!
Blake22211
Blake22211
Posted: Mon Nov 02, 2009 07:05 AM
Well, I was a bit anal about not burning anything in the interior...
lol those are towels covering just about everything.
but here is the end result after cutting and grinding and many @!%#&! 's lol
Hella comfortable. Also got the valves and timing done today. carb getting rebuilt tomorrow. found out the guy before me relocated the fuel filter right next to the exhaust, so a plastic filter is not going to cut it...getting a metal one tomorrow as well.
I assume this will work?
That's the one the previous owner put on there...
My Garage Link!
Blake22211
Blake22211
Posted: Tue Nov 03, 2009 06:24 PM
carb being rebuilt and tuned today by Relic VW, getting the car back tomorrow. Should run much better.
My Garage Link!
Blake22211
Blake22211
Posted: Tue Nov 10, 2009 09:03 AM
installed the electronic ignition, replaced plug wires and plugs, now have a Weber progressive tuned to perfection. car is hella fast!
You guy's would not believe the condition of the previous spark plugs...
All of the plugs were dark black for one. meaning way too rich.
Also, can you guess what the gap was for all of them?.... 0.060!!!!! holy macaroni!
Oh yeah, on top of that...the front two plugs I got out by hand. I gotta keep an eye on this car. I can't believe it was even running.
My Garage Link!
Blake22211
Blake22211
Posted: Thu Nov 19, 2009 09:58 AM
Well, update...getting a new engine this weekend.
There is a guy that sells rebuilt longblocks for semi-cheap. here are my choicecs...
-1600 for $550
-1641 for $600
-1776 for $750
core charge of $250 But I'm just gonna give him my old longblock that way I don't have to pay it...
suggestions?
My Garage Link!
jon6.0
jon6.0
Posted: Mon Nov 30, 2009 08:55 PM
Bigger is better.
Blake22211
Blake22211
Posted: Tue Dec 01, 2009 06:22 AM
jon6.0 wrote:
Bigger is better.
just ended up going with a dual port 1600. once it needs a rebuild I'll make it bigger but for now I'm working on suspension...even a small motor with great suspension can beat a big motor with little suspension
My Garage Link!
5 Admin_AzBaja 11676 Baja Bugs on Wiki need...
1569 mufasavnvmc 1196653 Re: what did you do to...
 Sat May 11, 2019 07:20 PM
285 MusicManiac 288404 Re: Baja sightings
103 SuburbanLegend 169425 Carbon Footprint...aka...
 Tue Sep 03, 2019 03:15 AM
Mykul View latest post
No new posts VW Volkswagen & Baja Bug General Discussion FREE VW BAJA'S 0 azdesertrat87 3597 FREE VW BAJA'S
