Latest: rcwtony
Overall: 3607
Visitors: 154
Total: 154
19: Home
53: Event Calendar
54: Home
60: My Account
82: Home
87: Home
106: Event Calendar
120: Home
142: Event Calendar
143: Event Calendar
148: Event Calendar
154: Baja Forums
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- They do it every time. (Rails for sale test)
Post Post subject: They do it every time. (Rails for sale test)
Posted: Mon Nov 09, 2009 01:00 AM
While looking like a decent starter rail to the untrained eye, not pefect but no oil leaks, nice paint, a decent rail was stripped the good stuff of and slapped togeher with what ever they had. The sellers misrepretation of the 40 hp engine as a 16000 cc engine is just the beginning. The good part is most of the problems are an easy fix but still costly. How many problems can you spot in these pictures.
I'll give you a hint on the first two. Replacing the missing shifter lock out plate made it worse not better.
This on the shifte is in the 3/4 position.
caversmoon
caversmoon
Posted: Mon Nov 09, 2009 01:49 AM
I hope that you picked it up real cheep
Post Post subject: Re: They do it every time. (Rails for sale test)
Posted: Mon Nov 09, 2009 02:08 AM
It is not mine but it will come back to life fast. In a few hours it will be functional for normal useage.
Posted: Mon Nov 09, 2009 03:10 PM
Its funny, In most cases it takes just as much effort to do it wrong as it does to do it right. I have seen some scary crap people have done on their VWs and luckily lived to tell about it.
Posted: Mon Nov 09, 2009 03:49 PM
x2 on effort. From the fancy paint job I suspect this was a former low travel Sand Queen with an expensive engine, transaxle and aluminium front end that was stripped of those parts for use with a newer chassis.
Posted: Tue Nov 10, 2009 01:09 AM
I ended up removing the end off the old shift rod and welded it to the end of the early weld in adjuster to convert it for use with a late model shifter coupler.
An hour later it shifts correctly and the reverse lock out works.
Posted: Tue Nov 10, 2009 01:13 AM
You do fine work perri!
2seaterbeater
2seaterbeater
Posted: Tue Nov 10, 2009 02:41 AM
yes perri is a very good man he has been helping me alot with this and is very helpful he explains things very well. i am a noob with vw's and he tells me everything i need to know! Thanks for all the help perri
Posted: Thu Nov 12, 2009 03:18 AM
Today I replaced the brake hoses, left front brake line and fixed the solid steel rear brake hoses.
The left front was to long and was rolled around in circles and kinked.
The main rear brake hose was a little short but since it was new I welded a bolt to the frame to secure the tee and rerouted the rear lines for a cleaner look.
Note the nice bow in the bowden tube.
Note the stout 3/32" acc cable
I think this rail had a hydraulic acc and clutch pedals before it got stripped "refurbished" and sold.
Posted: Thu Nov 12, 2009 06:19 AM
I still like the solid flex brake line to the rear.
Posted: Thu Nov 12, 2009 06:24 AM
If only I had known earlier I would off saved them for you. Very Happy
ChuckD
ChuckD
Posted: Thu Nov 12, 2009 07:24 AM
Such attrocities! i bought my baja in july and am still finding things that the guy before me screwed up. I mean theres cutting corners, and then theres just not doing it.
Posted: Sat Nov 14, 2009 11:12 PM
Last thing to do was look at the protruding wheel bearing. Two outer races were installed to makeup for the missing washer between the lock nut and bearing. The same thing was on the right side but the bearing cap was still on. Unfortunately it was the drivers bearing cap and the bearing was full of rust. The drivers wheel cylinder was leaking and the right side. The inner bearingas were stuck on by a thick coat of paint on the bearing and seal surface.
A quick trip to Dougs and Bap for the needed parts.
On word of warning the thrust washers sold need to be fitted to the axle. They are a poor unheat treated copy of VW Rabbit washers which also do not fit.
I unhooked the wire from the choke to the oil pressure switch.
It is amazing someone was to lazy to hook up the idle solenoid wire so they disconnected the choke heater so it would stay running.
Hooked up correctly it actually idled.
There at least another 10 hours to go but what would one expect when it got traded for some used tires. Good score Mario.
New User
2 Treeposter 2719 Time to let go....
 Wed Jun 21, 2017 11:23 PM
No new posts New Members 1968 VW for sale
baja for sale
0 papus67 3605 1968 VW for sale
 Thu Sep 11, 2014 07:04 AM
papus67 View latest post
No new posts New Members New Memb. First time post 3 Maxxh2o 3387 New Memb. First time ...
 Tue May 27, 2014 10:32 AM
No new posts Projects and Builds It's Time! Summer Upgrades
17 Yummi 16091 Re: It's Time! Summer...
 Fri Nov 22, 2013 05:10 AM
Yummi View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Felix Baumgartner test drives the Volkswagen XL1 0 trev0006 3217 Felix Baumgartner test...
 Fri Mar 08, 2013 07:37 AM
