Chirco.com
AzBaja Site info
 Latest: adamw444
 New Yesterday: 2
 Overall: 2217
 Visitors: 29
 Total: 29
Who Is Where: Visitors:01: Baja Forums
03: Amazon
04: Amazon
05: Pictures
06: Amazon
07: Amazon
10: Home
11: Amazon
12: Amazon
13: Amazon
15: Amazon
16: Amazon
17: Amazon
18: Amazon
19: Amazon
20: Amazon
22: Amazon
23: Amazon
24: Amazon
25: Amazon
26: Amazon
27: Amazon
29: Amazon
Staff Online:No staff members are online!
GPS
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Engines and Transaxles -:- somethin we've all forgotten or need to know......
Users browsing this topic:
None
Author |
Message |
BajaMan87
Post subject: Re: somethin we've all forgotten or need to know......
Posted: Thu Oct 11, 2007 05:55 PM
I see <said the blind man with a hat> thanks for the tip.when I get it running I will get a sump from another model.
_________________ Drive it like you stole it.
1972 VW Super Beetle BAJA
-259
Posted: Mon Mar 17, 2008 01:37 AM
their should be a post on common problems that people run into. and how to fix it
| jamesr6168 wrote: |
| CAUSE YOU WERE THINK,N WITH YOUR DIPSTICK,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,JIMMY! |
+7
-259
Posted: Mon Mar 17, 2008 01:40 AM
ok
i have a question for you what is the difference between super beetle and a standard bug
| jamesr6168 wrote: |
+7
Posted: Mon Mar 17, 2008 03:03 AM
Short answer:
Struts in the front of a super.
_________________ Buy from Chirco!!!
oldfart
+1
Posted: Mon Mar 17, 2008 04:05 PM
ok, if this is on topic....I assume everybody knows..
How to:
calm down after you think your transaxle is gone when you spot telltale metal shavings around your axle nut and drum.
drive home:
with a long ratchet after your shift tube support breaks.
with a broken throttle cable/clutch cable.
when the little fuel tube in the carb that looks like a faucet on your sink gets loose and is sucked into your engine, and whether it is gonna hurt or not...
with a iced up carburetor...
after that #3 spark plug blows out and you think you've been shot at...
when your fuel line rust thru leaving that wonderful smell inside your tunnel(for nonsmokers...those who do and are when it breaks...we'll miss you)
how to hotwire your bug if you lose your key or the ignition switch goes out right after you reach the top of the trail...
or maybe this isn't the right thread.
_________________ 8 (!) grandkids. I'm old and smell funny.
mikey
Posted: Mon Jan 11, 2010 04:08 PM
if i put a high volume oil pump on my 1500 will i need to put a sump on it that holds 1.1/2 more quarts of oil
_________________ everything looks better with mud on it
Baja_Blue
+6
Posted: Mon Jan 11, 2010 09:13 PM
| oldfart wrote: |
How to:
calm down after you think your transaxle is gone when you spot telltale metal shavings around your axle nut and drum. |
Just keep driving!!
| oldfart wrote: |
drive home:
I had to do that with the throttle cable, I put it through a hole I had in the firewall at the time and pulled it with my hand hahaha
_________________ 1600 Dual Port, Class 11 Roll Cage, Crow Harnessess, Racetrim Seats, IRS, KYB gas-a-justs, Skidplates front and rear, Procomp Streetlock Wheels w/29" tires, Pioneer Head-Unit w/300W Speakers, mostly stock but so much fun!!
Matthew 5:14-16
My Garage Link!
You can download files in this forum
Baja Bugs and Buggies
Picture Box
Store
0 items Cart Value: 0.00
