Latest: rcwtony
Overall: 3607
Visitors: 175
Total: 175
27: Event Calendar
44: Event Calendar
59: Event Calendar
62: Event Calendar
80: Event Calendar
81: Event Calendar
91: My Account
104: Home
105: My Account
111: Home
119: Event Calendar
138: Event Calendar
142: Event Calendar
149: Event Calendar
151: Event Calendar
154: Baja Forums
158: Baja Forums
164: Baja Forums
175: Event Calendar
Baja Forums -:- AzBaja.com Members -:- Projects and Builds -:- Earnest's Baja Project
saturnbug
saturnbug
Post Post subject: Re: Earnest's Baja Project
Posted: Tue Dec 22, 2009 08:49 PM
how does the rad do at highway speeds?I have seen the rad mounted up front under the hood before but if it gets good air in the back that would be a easier way to go.
Buggyboat
Buggyboat
Posted: Sun Jan 17, 2010 03:05 PM
This is a way cool bug. I think it said that the rear arms are boxed, and it did not appear that a cage went in. How/where are you going to mount the rear shocks?
Posted: Mon Jan 18, 2010 06:06 PM
I couldn't find the pic in the thread, but he built a rear shock mount in the cabin. Once Daryll sees this he will post up the pic. Cool
jk97
jk97
Post Post subject: Earnest's Baja Project
Posted: Thu Jan 21, 2010 05:35 AM
Nice work. That's is one sweet ride.
Jim
jk97
'66 Berry Mini-T IV
SuburbanLegend
SuburbanLegend
Posted: Fri Apr 02, 2010 04:38 PM
I'm trying to wire up my Ecotec engine and have about a million questions. Here are just two:
1) where did you mount the computer and relays...inside or outside the car? If inside, where you able to seal off the hole where the wire loom comes through? Would it be safe enough outside the car on the firewall?
2) What water temp and oil pressure gauge senders did you use? I'm having a hard time finding the right ones.
Posted: Sat Apr 10, 2010 06:40 AM
You can get the oil temp & oil pressure tread adapter through autometer. It fits on the exhaust side of the motor. The temp sender we just drilled and tapped an 1/8 NPT hole.
vwJ420
vwJ420
Posted: Tue May 25, 2010 05:10 AM
that thing is sexy
J
5 Admin_AzBaja 10441 Baja Bugs on Wiki need...
1569 mufasavnvmc 1146643 Re: what did you do to...
 Sat May 11, 2019 07:20 PM
285 MusicManiac 276852 Re: Baja sightings
103 SuburbanLegend 159282 Carbon Footprint...aka...
 Tue Sep 03, 2019 03:15 AM
Mykul View latest post
No new posts VW Volkswagen & Baja Bug General Discussion FREE VW BAJA'S 0 azdesertrat87 2828 FREE VW BAJA'S
