AzBaja.com, Home of the VW Baja Bug Chirco.com
Toggle Content Chirco.com
Latest: adamw444
New Yesterday: 2
Overall: 2217
Visitors: 28
Total: 28
02: Amazon
03: Amazon
04: Amazon
05: Amazon
06: Amazon
09: Amazon
10: Amazon
12: Amazon
14: Amazon
15: Amazon
19: Amazon
20: Amazon
21: Amazon
22: Amazon
23: Amazon
26: Amazon
27: Amazon
28: Amazon
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- Tech, Tips, Things to know. -:- HOW TO: Re-bushing Kadron Throttle Bodies
Store
VW Books For Sale
Post Post subject: HOW TO: Re-bushing Kadron Throttle Bodies
Posted: Fri Feb 05, 2010 08:53 AM
So here's my super-duper triple-patented patented way to re-bush those old worn-out throttle bodies that Kadron is so well known for. If anyone has any suggestions as to how to improve this method, or any other insights, thoughts, or ideas; I'd love to hear them. I'm always eager to learn....
First, we start off with high-quality German bronze bushings manufactured inside in steel casings. These are impregnated with PTFE Teflon for maximum lubrication. These bushings should last for our generation, and many more after that. These are super beefy.
Check one out against the stock bushing still inside the carb. Look how thin and skimpy that little dude is compared to these. Like I said... You won't wear these bad boys out! They're a little expensive, but well worth it.
Next, we see that if you try to get the screws out of these butterfly valves, they usually do this. They get all chewed up. They peen the back of these when they put them in so you don't suck one down in your intake system. Not a bad idea. We'll return to that thought later.
So what do you do? You drill them out. Better have some extras on hand. They'll need to be replaced, too. Also... I made a jig to hold the throttle body at he exact angle to facilitate drilling a straight hole through the retainer screw.
When you drill the screws out, you'll need to probably remove the threaded middle with an ez-out.
You might also need to chase the threads, so make sure you have a 4mm x 0.7mm tap handy Then, remove the throttle plate (butterfly). Remove the linkage arm and rotating stopper assembly and pull out the rod that goes through the throttle body.
After removing the throttle body rod, I put it in a vise and polish the shaft with strips of very fine sandpaper. I also clean the butterfly. It just looks nicer that way.
Here are a couple "BEFORE" and "AFTER" shots:
I made another jig to make the next part easy and keep the holes straight. Drill a hole in each side of the throttle body to fit the bushing. In this case, I use a 10mm diameter OD bearing (or bushing, depending on who you ask). The hole is 9.7mm deep to accommodate the bushing size.
Be careful! It's super easy to drill all the way through. Holes are much harder to "undrill", I've found.
Tap your bushings in (or press, as necessary). I'm also using a little JB Weld on mine to keep them from spinning when they aluminum heats up. If I'm going to be modifying the carb for vacuum advance, I cut a small piece of .0403" aluminum wire, coat it in JB weld, and fill the little hole in the throttle body as shown. Don't fill the wrong hole or your throttle body will be instant junk! This creates the proper vacuum signal for the VW distributors when adding the port for the advance on the case of the carb. The carb was pre-designed like this, but never imported into the USA with this factory option.
After 24 hours, I return and sand the filler smooth.
Reassemble very carefully, especially when sliding the throttle plate back inside the holder. Make sure its orientation is correct, as it sits very tightly inside the body when the butterfly valve is closed. Install your new screws and tighten them only when it seats right, checking, and double-checking everything as it opens and closes.
When everything's right peen the back of the screw. I also use Loctite on mine. Assemble the linkage connecting arms as needed. Remember: Stock ones have a left and right. The "Outie" is for the driver's side, and the "Innie" is for the passenger's side. Scat linkage has the ball drilled out and both offsets point the same way. The offset points out. I Loctite mine on, as well as re-bending the little thin washer.
Voila, you're done!
.... And yes.... I can do this for you. PM me if interested.
Jeff's "Kaddie Shack" Custom Kadron Carburetors and Kadron Parts/Accessories for sale
Baja_Blue
Baja_Blue
Posted: Fri Feb 05, 2010 09:02 AM
nice job with a very detailed 'How To' Cool
1600 Dual Port, Class 11 Roll Cage, Crow Harnessess, Racetrim Seats, IRS, KYB gas-a-justs, Skidplates front and rear, Procomp Streetlock Wheels w/29" tires, Pioneer Head-Unit w/300W Speakers, mostly stock but so much fun!!
Matthew 5:14-16
My Garage Link!
Posted: Sat Feb 06, 2010 03:29 AM
Thank you. I thought a few more people would have seen it, but this is a new area, so I understand. Nobody is looking here yet.
Posted: Mon Feb 08, 2010 09:13 PM
Looks good, glad you are buying these things up and rebuilding them.
No new posts I have something to sell Kadron Dual Carb Set-up Complete
Turn-Key with 90 Day Warranty
12 57baja 1029 Kadron Dual Carb Set-u...
 Sun Jul 25, 2010 04:06 AM
65bajabug View latest post
No new posts I have something to sell Custom Kadron carburetor set ups 0 57baja 159 Custom Kadron carburet...
 Thu Jun 17, 2010 07:12 AM
57baja View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Modification to Kadron Carbs for Off-Road & Better Breathing 7 57baja 510 Modification to Kadron...
 Fri May 28, 2010 01:26 AM
No new posts I have something to sell "Turn Key" Off-Road Kadron Carburetors
With 90-Day warranty and installation tech service
0 57baja 252 "Turn Key" Off-Road Ka...
 Fri May 14, 2010 08:30 AM
No new posts VW Suspension, Brakes, Wheels and Tires Has anyone used this rear bushing kit?
Found on mamotorworks.com
11 Billy 372 Has anyone used this r...
 Mon May 10, 2010 12:37 AM
Billy View latest post
You can download files in this forum
Toggle Content Baja Bugs and Buggies
Toggle Content Store
show cart or checkout0 items
Cart Value: 0.00
We are not responsible for comments posted by our users, as they are the property of the poster.
