AzBaja.com, Home of the VW Baja Bug This Space for RENT!
Toggle Content Chirco.com
Latest: kozilla
Overall: 2039
Visitors: 19
Total: 19
03: Home
04: Store
05: Home
07: Store
09: Store
10: Store
12: Pictures
14: Store
15: Store
19: Store
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- Tech, Tips, Things to know. -:- HOW TO: Re-bushing Kadron Throttle Bodies
Store
VW Books For Sale
Post Post subject: HOW TO: Re-bushing Kadron Throttle Bodies
Posted: Fri Feb 05, 2010 07:53 AM
So here's my super-duper triple-patented patented way to re-bush those old worn-out throttle bodies that Kadron is so well known for. If anyone has any suggestions as to how to improve this method, or any other insights, thoughts, or ideas; I'd love to hear them. I'm always eager to learn....
First, we start off with high-quality German bronze bushings manufactured inside in steel casings. These are impregnated with PTFE Teflon for maximum lubrication. These bushings should last for our generation, and many more after that. These are super beefy.
Check one out against the stock bushing still inside the carb. Look how thin and skimpy that little dude is compared to these. Like I said... You won't wear these bad boys out! They're a little expensive, but well worth it.
Next, we see that if you try to get the screws out of these butterfly valves, they usually do this. They get all chewed up. They peen the back of these when they put them in so you don't suck one down in your intake system. Not a bad idea. We'll return to that thought later.
So what do you do? You drill them out. Better have some extras on hand. They'll need to be replaced, too. Also... I made a jig to hold the throttle body at he exact angle to facilitate drilling a straight hole through the retainer screw.
When you drill the screws out, you'll need to probably remove the threaded middle with an ez-out.
You might also need to chase the threads, so make sure you have a 4mm x 0.7mm tap handy Then, remove the throttle plate (butterfly). Remove the linkage arm and rotating stopper assembly and pull out the rod that goes through the throttle body.
After removing the throttle body rod, I put it in a vise and polish the shaft with strips of very fine sandpaper. I also clean the butterfly. It just looks nicer that way.
Here are a couple "BEFORE" and "AFTER" shots:
I made another jig to make the next part easy and keep the holes straight. Drill a hole in each side of the throttle body to fit the bushing. In this case, I use a 10mm diameter OD bearing (or bushing, depending on who you ask). The hole is 9.7mm deep to accommodate the bushing size.
Be careful! It's super easy to drill all the way through. Holes are much harder to "undrill", I've found.
Tap your bushings in (or press, as necessary). I'm also using a little JB Weld on mine to keep them from spinning when they aluminum heats up. If I'm going to be modifying the carb for vacuum advance, I cut a small piece of .0403" aluminum wire, coat it in JB weld, and fill the little hole in the throttle body as shown. Don't fill the wrong hole or your throttle body will be instant junk! This creates the proper vacuum signal for the VW distributors when adding the port for the advance on the case of the carb. The carb was pre-designed like this, but never imported into the USA with this factory option.
After 24 hours, I return and sand the filler smooth.
Reassemble very carefully, especially when sliding the throttle plate back inside the holder. Make sure its orientation is correct, as it sits very tightly inside the body when the butterfly valve is closed. Install your new screws and tighten them only when it seats right, checking, and double-checking everything as it opens and closes.
When everything's right peen the back of the screw. I also use Loctite on mine. Assemble the linkage connecting arms as needed. Remember: Stock ones have a left and right. The "Outie" is for the driver's side, and the "Innie" is for the passenger's side. Scat linkage has the ball drilled out and both offsets point the same way. The offset points out. I Loctite mine on, as well as re-bending the little thin washer.
Voila, you're done!
.... And yes.... I can do this for you. PM me if interested.
Baja_Blue
Baja_Blue
Posted: Fri Feb 05, 2010 08:02 AM
nice job with a very detailed 'How To' Cool
Straights are for fast cars...Turns are for fast drivers
Matthew 5:14-16
My Garage Link!
Posted: Sat Feb 06, 2010 02:29 AM
Thank you. I thought a few more people would have seen it, but this is a new area, so I understand. Nobody is looking here yet.
Posted: Mon Feb 08, 2010 08:13 PM
Looks good, glad you are buying these things up and rebuilding them.
No new posts I have something to sell Kadron Dual Carb Set-up Complete
Turn-Key with 90 Day Warranty
7 57baja 174 Re: Kadron Dual Carb S...
 Wed Mar 10, 2010 04:06 PM
Preston View latest post
No new posts I have something to sell Rebuilt/Re-bushed SVDA Kadron Carbs with warranty
Also: New Air Cleaners, Bases, Hoses, Clamps... Turn-Key!!!
4 57baja 71 Rebuilt/Re-bushed SVDA...
 Fri Mar 05, 2010 02:11 AM
57baja View latest post
No new posts I have something to sell Complete Kadron Overhaul Kit with 90 Day Warranty
Get your Kaddies running like a Caddie
0 57baja 66 Complete Kadron Overha...
 Mon Feb 15, 2010 07:04 AM
No new posts VW Engines and Transaxles throttle cable questions... 8 Brettucks 145 Re: throttle cable que...
 Wed Feb 10, 2010 05:26 PM
bajawarrior View latest post
No new posts I have something to sell Rebuilt Kadron Dual Carbs - Complete Kit
With warranty!
0 57baja 106 Rebuilt Kadron Dual Ca...
 Tue Jan 19, 2010 11:53 PM
You can download files in this forum
Toggle Content Baja Bugs and Buggies
Toggle Content Store
show cart or checkout0 items
Cart Value: 0.00
Toggle Content Posters, DVD, and More
We are not responsible for comments posted by our users, as they are the property of the poster.
