Chirco.com
AzBaja Site info
 Latest: kozilla
 Overall: 2039
 Members: 3
 Visitors: 9
 Total: 12
Who Is Where: Members:01: Baja_Blue > Baja Forums
02: BugLife > Baja Forums
03: macbaine > Baja Forums
Visitors:01: Store
03: Pictures
06: Home
08: Store
Staff Online:No staff members are online!
GPS
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Engines and Transaxles -:- Blow By/crank case pressure
Users browsing this topic:
None
Author |
Message |
TrailRail2110
Post subject: Blow By/crank case pressure
Posted: Thu Feb 04, 2010 04:11 AM
Im new to the forum, i just added pics of my buggy to the new member section go check it out.
I have a couple quick questions. Just pulled my motor and found a standing oil in my bell house also my clutch looks dirty/oily. not sure it my seal is bad, cause its also coming out of the pulley to, i think it might be the case pressure is to high. i was thinking of an oil breather?
also, my flywheel has some small groves on the surface. looks like a used not trashed brake rotor. at what point do i need to get it resurfaced?
TrailRail2110
Posted: Mon Feb 08, 2010 03:47 PM
Anyone have any suggestions about these?
Baja_Blue
+3
Posted: Mon Feb 08, 2010 06:22 PM
replace the rear main seal and that should fix the oil in the bellhousing problem.
I had the same issue with it leaking behind the pulley. If it is the sand seal kind, take it off and check for the spacer and see if the rubber on the sand seal is still there. If not, replace em. If their fine, a breather should work. I replaced them both and got a breather and it stopped leaking
not sure what to do about the flywheel
_________________ Straights are for fast cars...Turns are for fast drivers
Matthew 5:14-16
My Garage Link!
+34
Post subject: Re: Blow By/crank case pressure
Posted: Mon Feb 08, 2010 08:01 PM
X2 on the seal and o ring make sure the end play is within specs. Polish where the seal rides.
As for the roughness where the clutch disc goes it does not really matter. When you replace the assembly you could/should get it resurfaced.
TrailRail2110
Posted: Mon Feb 08, 2010 08:36 PM
Ok, I will replaced both seals or at least check them. I also get the notion i should just get the flywheel resurfaced anyway while its off.
Do any of you have a preference of oil breather i was looking at the standard empi foam style...?
Brettucks
Captain
+7
Posted: Tue Feb 09, 2010 02:53 AM
Replace both the clutch and pressure plate or neither... same problem as brake rotors.. if your clutch is 'worn' into the grooves of the pressure plate and replace only one you will create hot spots.. can get pressure plate turned but if unsure how wore it is I would replace both for peace of mind.. if not clean the oil out of the clutch area and let both stay..
-Brett
_________________ baja will be driving around, and SOON...
TrailRail2110
Posted: Tue Feb 09, 2010 05:52 PM
I was going to switch from a stock pressure plate and looks like stock sprung disc, over to a KEP stage 1 and Rigid Kush-lock/daiken. i was getting a ton of slip when i punched the gas, it would just spin.
Also, what kind of oil breather does everyone use? Plus, how do you like it?
Baja_Blue
+3
Posted: Tue Feb 09, 2010 08:50 PM
I use the empi breather. seems to work great
Matthew 5:14-16
My Garage Link!
Rickman
+3
Posted: Tue Feb 09, 2010 09:25 PM
_________________ I've never been lost, disoriented maybe but not lost.
+34
Posted: Tue Feb 09, 2010 11:48 PM
I use the tall breather can that has a K&N filter built in. Oil on your new clutch disc will make it slip. It is similar to Chirco part #CPR129376
www.chircoestore.com/c...129376.jpg
The Stage 1 pressure plate and Daiken disc work well together.
TrailRail2110
Posted: Sat Feb 13, 2010 05:41 PM
Thank you for all that info and pictures, a huge help!
I got this oil breather, which should be good for all the rain, mud and dust i see. plus i was told that the stock empi is not big enough for my 2110...
I ended up finding a place that will turn my flywheel for $30 and they said they would help put the gland nut back on to a torque spec of 217lbs. my torque wrench only goes to 150lbs.
_________________ A funny thing to do is, if you're out hiking and your friend gets bitten by a poisonous snake, tell him you're going to go for help, then go about ten feet and pretend that *you* got bit by a snake. Then start an argument with him about who's going to go get help. A lot of guys will start crying. That's why it makes you feel good when you tell them it was just a joke.
-Jack Handy
You can download files in this forum
Baja Bugs and Buggies
Store
0 items Cart Value: 0.00
Posters, DVD, and More
