AzBaja.com, Home of the VW Baja Bug This Space for RENT!
Toggle Content Chirco.com
Latest: kozilla
Overall: 2039
Members: 1
Visitors: 15
Total: 16
 Members:
01: chickenpants > Baja Forums
01: Store
02: My Account
04: Store
05: Store
08: Store
09: Store
12: Store
13: My Account
14: Home
15: My Account
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- oil cooler setup..
Store
VW Books For Sale
oil cooler setup..
Brettucks
Captain
Captain
Brettucks
Post Post subject: oil cooler setup..
Posted: Sun Feb 07, 2010 09:19 PM
I currently have the kit that has filter mounted to oil pump cover (filter sits horizonatlly to the left)...
Could I just get one of those spin-on sandwhich adapters to run the oil lines to/from the cooler?
-Brett
baja will be driving around, and SOON...
Post Post subject: Re: oil cooler setup..
Posted: Mon Feb 08, 2010 02:29 AM
You could. There used to be a kit for the T-4 that worked that way.
Posted: Mon Feb 08, 2010 03:37 AM
I'm a big fan of those filter/pump combos, and have been running them for years. I thought of that exact same thng once, and actually even bought the adapter. After looking very closely at it, I dcided against it. The holes to let the oil in and out were quite small and looked very restrictive. It made me real nervous, so I crawfished on the whole idea and went a different route.
I was reading about how they full-flow type 3's the other day, and I might try that on an engine some day. It was really cool. On a T3, you don't have any room to pump the oil out at the filter and then back behind the engine because the fan shroud interferes with it. They drill a hole in the side of the case by where the oil pressure sender is on a T1 and put a plug in between them to force the oil out an back in. I wouldn't try that with an assembled engine, though.
Baja_Blue
Baja_Blue
Posted: Mon Feb 08, 2010 03:43 AM
hey speaking of oil pressure sender hole...Mine has a a hose going all the way to the front of the car to the oil pressure gauge!
kinda scares me I have oil running all the way to the front...
anyone else have this?
sorry for the thread jack...
Straights are for fast cars...Turns are for fast drivers
Matthew 5:14-16
My Garage Link!
Posted: Mon Feb 08, 2010 04:47 AM
Scares me to and it is not even my engine. It does not take long to drain a running engine of oil when the plastic hose rubs through on a sharp piece of metal.
Baja_Blue
Baja_Blue
Posted: Mon Feb 08, 2010 07:00 AM
yeah I put 300psi rated hose to the metal line it goes to. I'm thinking I convert it to electronic pretty soon here
anyone ever heard of even having this? every VW mechanic I've gone to has said the same thing..."what the hell is that for?" lol
Matthew 5:14-16
My Garage Link!
Brettucks
Captain
Captain
Brettucks
Posted: Tue Feb 09, 2010 01:57 AM
Sounds like the ole 'mechanical' guages... I had a ford truck with one that did get cut ... didnt run out of oil but foot was showered with hot oil for about 5 seconds till I turned it off and coasted anyway..
I think this is not full flow but doing it anyway as it is much easier for now.. plus if head temperature guages get hooked up I will have some warning, and if oil cooler gets harmed you can just spin off filter, spinoff adapter and reassemble... filter being inside cage will give some insurance..
-Brett
No new posts VW Volkswagen & Baja Bug General Discussion Carb and intake setup? 11 Torg37 214 Carb and intake setup?
 Fri Feb 05, 2010 02:26 AM
57baja View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Best carb setup for regular street use and some off road 1 trailblazr81 165 Re: Best carb setup fo...
 Tue Jan 05, 2010 05:52 AM
No new posts VW Engines and Transaxles oil cooler 1 big0067 302 Re: oil cooler
 Fri Aug 14, 2009 04:03 AM
No new posts I have something to sell looking for oil cooler 6 Kev_n_AZ 256 Re: looking for oil co...
 Mon Jun 01, 2009 11:32 PM
Kev_n_AZ View latest post
No new posts VW Engines and Transaxles Oil (Remote Filter and cooler) check valve?
Need some advice
2 Conundrum 241 Oil (Remote Filter and...
 Sat Apr 25, 2009 09:26 PM
You can download files in this forum
Toggle Content Baja Bugs and Buggies
Toggle Content Store
show cart or checkout0 items
Cart Value: 0.00
Toggle Content Posters, DVD, and More
We are not responsible for comments posted by our users, as they are the property of the poster.
