Chirco.com
AzBaja Site info
 Latest: kozilla
 Overall: 2039
 Members: 1
 Visitors: 24
 Total: 25
Who Is Where: Members:01: Specialone70 > Baja Forums
Visitors:01: Baja Forums
03: Home
04: Store
07: Store
09: Store
10: Video Wall
11: Store
12: Store
14: Home
16: Home
18: Home
19: Store
20: Store
23: Store
24: Store
Staff Online:No staff members are online!
GPS
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Engines and Transaxles -:- throttle cable questions...
Users browsing this topic:
None
Author |
Message |
Brettucks
Captain
+7
Post subject: throttle cable questions...
Posted: Sat Feb 06, 2010 03:05 PM
On tyhr proseatz car the cable was installed on the drivers side, but I belive the car had a dual carb setup..
The engine I gothas dual carbs with the throttle arm positioned near hole in fan shroud, but for some reason the hole is too low or the arnm is too short (I believe the housing is in correctly...)
could I -
1- move the throttle arm down the shaft toward the drivers side (would it work there or must it be in middle)
2-make and extended throttle arm at my work (and verify it will have full travel before I make one).
-Brett
_________________ baja will be driving around, and SOON...
Brettucks
Captain
+7
Posted: Tue Feb 09, 2010 02:01 AM
Please guys- this is holding everything up-- does it HAVE to be in the middle? throttle 'bar' rotates between two points off of carbs... is front and back direction, not transformed into side-to-side action. If I need to keep it in center let me know.. the arm is capable of being postioned anywhere on the bar but want to know if it will work anywhere on bar...
-Brett
cyberjaw4
+3
Posted: Tue Feb 09, 2010 02:56 AM
Pic's would help for someone to help you so if you can get some pic's of it that would be nice
Brettucks
Captain
+7
Posted: Tue Feb 09, 2010 03:08 AM
this is problem area
this pic shows that side mount aint gonna happen..
this is in general (some people were asking for a progress report)
Is there a common reason for this? (Fan shroud was on this engine before but it looks like it sits high even now).. and recommendations, like fabricating arm?
_brett
Brettucks
Captain
+7
Posted: Tue Feb 09, 2010 03:09 AM
sorry about the big pics... should have reduced...
+34
Post subject: Re: throttle cable questions...
Posted: Tue Feb 09, 2010 03:49 AM
It does not have to be in the middle.
+27
Brettucks
Captain
+7
Posted: Wed Feb 10, 2010 02:32 AM
I never thought of option #3 but thats the winner-- Thannks!!
-Brett
Staff Officers
+23
Posted: Wed Feb 10, 2010 05:26 PM
| Brettucks wrote: |
| Please guys- this is holding everything up-- does it HAVE to be in the middle? throttle 'bar' rotates between two points off of carbs... is front and back direction, not transformed into side-to-side action. If I need to keep it in center let me know.. the arm is capable of being postioned anywhere on the bar but want to know if it will work anywhere on bar... -Brett |
I ran the the linkage all the way over to the side because i was running a center mount fan shroud. But you must make sure there is no slop of any kind between the arms and the hex bar, if there is you will end up giving throttle to one carb before the other. so make sure you use lock tight and tighten everything good.
_________________ www.proseatz.com/
www.drummondrace.com/
AzBaja Event Coordinators Mr. and Mrs. Baja Warrior
Where the blacktop ends....the fun begins!! :)
You can download files in this forum
Baja Bugs and Buggies
Store
0 items Cart Value: 0.00
Posters, DVD, and More
