Toggle Content Chirco.com
Latest: adamw444
New Yesterday: 2
Overall: 2217
Visitors: 31
Total: 31
01: Amazon
02: Amazon
03: Amazon
04: Amazon
05: Amazon
06: Amazon
07: Amazon
08: Event Calendar
09: Amazon
12: Amazon
14: My Account
15: Amazon
16: Amazon
19: Amazon
21: Amazon
22: Amazon
23: Amazon
24: Home
25: Amazon
28: Amazon
29: Home
30: Amazon
31: Amazon
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Engines and Transaxles -:- throttle cable questions...
Store
VW Books For Sale
Brettucks
Captain
Captain
Brettucks
Post Post subject: throttle cable questions...
Posted: Sat Feb 06, 2010 04:05 PM
On tyhr proseatz car the cable was installed on the drivers side, but I belive the car had a dual carb setup..
The engine I gothas dual carbs with the throttle arm positioned near hole in fan shroud, but for some reason the hole is too low or the arnm is too short (I believe the housing is in correctly...)
could I -
1- move the throttle arm down the shaft toward the drivers side (would it work there or must it be in middle)
2-make and extended throttle arm at my work (and verify it will have full travel before I make one).
-Brett
Brettucks
Captain
Captain
Brettucks
Posted: Tue Feb 09, 2010 03:01 AM
Please guys- this is holding everything up-- does it HAVE to be in the middle? throttle 'bar' rotates between two points off of carbs... is front and back direction, not transformed into side-to-side action. If I need to keep it in center let me know.. the arm is capable of being postioned anywhere on the bar but want to know if it will work anywhere on bar...
-Brett
cyberjaw4
cyberjaw4
Posted: Tue Feb 09, 2010 03:56 AM
Pic's would help for someone to help you so if you can get some pic's of it that would be nice
Brettucks
Captain
Captain
Brettucks
Posted: Tue Feb 09, 2010 04:08 AM
this is problem area
this pic shows that side mount aint gonna happen..
this is in general (some people were asking for a progress report)
Is there a common reason for this? (Fan shroud was on this engine before but it looks like it sits high even now).. and recommendations, like fabricating arm?
_brett
Brettucks
Captain
Captain
Brettucks
Posted: Tue Feb 09, 2010 04:09 AM
sorry about the big pics... should have reduced...
Post Post subject: Re: throttle cable questions...
Posted: Tue Feb 09, 2010 04:49 AM
It does not have to be in the middle.
Posted: Tue Feb 09, 2010 08:46 AM
Option 3: drill another hole in the fan shroud? You wouldn't be the first guy I've seen with two throttle cable holes in the shroud.
Option 4: drill another hole in the air cleaner stand-off brackets, thread it and lower your cross-bar.
Just tossing out additional options you might not have thought of. Who was it that was saying that 90% of VW stuff you buy is something to start with? Most everything needs to be modified to make it work properly!
Jeff's "Kaddie Shack" Custom Kadron Carburetors and Kadron Parts/Accessories for sale
Brettucks
Captain
Captain
Brettucks
Posted: Wed Feb 10, 2010 03:32 AM
I never thought of option #3 but thats the winner-- Thannks!!
-Brett
Staff Officers
Posted: Wed Feb 10, 2010 06:26 PM
Brettucks wrote:
Please guys- this is holding everything up-- does it HAVE to be in the middle? throttle 'bar' rotates between two points off of carbs... is front and back direction, not transformed into side-to-side action. If I need to keep it in center let me know.. the arm is capable of being postioned anywhere on the bar but want to know if it will work anywhere on bar... -Brett
I ran the the linkage all the way over to the side because i was running a center mount fan shroud. But you must make sure there is no slop of any kind between the arms and the hex bar, if there is you will end up giving throttle to one carb before the other. so make sure you use lock tight and tighten everything good.
www.proseatz.com/
www.drummondrace.com/
AzBaja Event Coordinators Mr. and Mrs. Baja Warrior
Where the blacktop ends....the fun begins!! :)
No new posts VW Volkswagen & Baja Bug General Discussion Welding Questions 13 Rickman 466 Re: Welding Questions
 Thu May 13, 2010 09:56 PM
Billy View latest post
No new posts VW Suspension, Brakes, Wheels and Tires Couple last questions before I replace rear suspension 0 Billy 139 Couple last questions ...
 Fri Apr 30, 2010 12:25 AM
No new posts VW Volkswagen & Baja Bug General Discussion Tow Bar Questions 10 Rickman 400 Re: Tow Bar Questions
 Sat Apr 10, 2010 04:40 AM
No new posts VW Engines and Transaxles Basic Engine building Questions
I'm new here
7 chvyhs 554 Basic Engine building ...
 Fri Mar 05, 2010 06:08 PM
chvyhs View latest post
No new posts VW Engines and Transaxles Questions about Dellorto 7 1450bug 352 Questions about Dellor...
 Thu Feb 18, 2010 10:38 PM
BugLife View latest post
You can download files in this forum
Toggle Content Baja Bugs and Buggies
Toggle Content Store
show cart or checkout0 items
Cart Value: 0.00
We are not responsible for comments posted by our users, as they are the property of the poster.
