Visitors: 131
Total: 131
04: Pictures
26: Event Calendar
39: Home
44: Event Calendar
117: Event Calendar
124: Event Calendar
129: My Account
130: Event Calendar
Baja Forums -:- AzBaja.com Members -:- Projects and Builds -:- MURZ's BAJA
MURZ's BAJA
MURZ
MURZ
Post Post subject: MURZ's BAJA
Posted: Wed Jun 02, 2010 03:14 AM
Greeting from the oil slicked, Katrina blown area of the world!!!!
MURZ, here......
Just picked up a rust free 68 baja. Plans are to build it up into a street baja with a wicked nasty IDA fed 2276. The body needs paint and probably will be painted VOODOO blue (FJ Cruiser color). I am debating between chevy pattern WELD wheels or wide five centerlines. I love the look of the centerlines, but they have doubled in price in the last couple of years. Weld wheels are an easy find most days on craigslist.
Engine is unknown displacement and has 175lbs of compression in each hole.... .448" lift cam. Full flowed... I stuck some 45 dells on it today and it sounds like a very angry two stroke!!! I plan on pulling it down for exploratory surgery and refresh. It runs good, but i wont be able to sleep at night not knowing what it is.....
www.youtube.com/watch?v=908t3qNteYk
Some pics....
If I were to order a new baja kit(to save bodywork time) who makes the best kit???
MURZ
Rickman
Rickman
Post Post subject: Re: MURZ's BAJA
Posted: Wed Jun 02, 2010 04:03 PM
Welcome to AZBaja.com, MURZ!
Nice looking Baja too! Keep us posted .
Posted: Wed Jun 02, 2010 04:16 PM
Welcome to AZBAJA. Nice material to start your project with. Interesting coil mount. Smile Carbs sounded out of sync. MArk V Fiber Glass in Nevada for the kit.
MURZ
MURZ
Posted: Wed Jun 02, 2010 05:31 PM
Yea, how you like that fan shroud too?? Just a test run, did not touch the carbs...just bolted them on.
Posted: Wed Jun 02, 2010 06:38 PM
I thought it was very stealth. I knew it weas only a test fire. I just don't like the sound of unsyncronized carbs. Smile
MURZ
MURZ
Posted: Wed Jun 02, 2010 07:24 PM
I know this is very unscientific, but with 175lbs of cranking compression, what do you guys estimate the compression ratio to be....at least 10:1 huh??
I went out and sync the carbs, and did a best lean idle....these babies are probably way too big for this engine. 45 dells, with 38 vents, 70 idles, 170 mains, 200 airs. Throttle response is not crisp at all.... I also have a set of 44 webers with 36 vents I can try on it..
I guess I first need to at least pull one head to see what I am dealing with...valve size, pistons, and stroke. PO said it was a 1800....I said cool made no big deal of it. When I got it home I measured valve lift at .448-450 and the heads are stamped 94. Compression was 175 and the heads have been ported. I really dont think the guy knew what he had...
Posted: Wed Jun 02, 2010 09:06 PM
Cam duration, altitude, throttle plates open or close affect compression psi readings.
A rough conversion is:
Cranking pressure (psi) = CR raised to the 1.3 power x 14.7 x 2/3x .90 (average after market cam) Your compression psi works out to 10.0 to 1
Don't multiply by .90 if it is a stock cam.
For a Mild cam us .95, for drag racing use .85
MURZ
MURZ
Posted: Thu Jun 10, 2010 12:58 AM
OK, done to bidness. Got some sanding done on the car, stripped the interior, and ordered a bunch of stuff. Still can't find any reasonably priced wide five centerlines!!!! DAMN!!!!
Posted: Thu Jun 10, 2010 01:34 AM
You have been very busy.
MURZ
MURZ
Posted: Thu Jun 10, 2010 02:48 AM
Yes, I have!! The PO left me some nice evenly spaced holes in the roof!!!! I guess they were for lights. When I started sanding the roof, one by one they fell into the headliner. I pulled the windshield, and pulled the headliner back to expose the holes. The plan is to just back the holes with quarter sized 16 gauge sheet metal, mig them in and skim with some body filler. I still can not get over how a 1968 can have NO rust!!
MURZ
MURZ
Posted: Thu Jun 10, 2010 04:15 PM
Did some dash mockup. Gonna run ABS plastic and stick all switches under the dash for a clean look.....
MURZ
MURZ
Posted: Sat Oct 16, 2010 12:14 AM
some updates...... cut a hole in the roof for a streetbeat ragtop. filled the dash.....and 100 hours of block sanding and priming
Posted: Wed Oct 27, 2010 05:29 AM
I see toes.
bajaboi727
bajaboi727
Posted: Wed Oct 27, 2010 11:41 PM
The picture of the car with a ragtop? Am I missing something? or ??
MURZ
MURZ
Posted: Tue Nov 02, 2010 05:53 AM
A few updates.....Black paint!!!
1568 mufasavnvmc 856973 Re: what did you do to...
285 MusicManiac 209643 Re: Baja sightings
Off-road event
1 wideopenmotorsports 392 Re: Baja run in March
 Mon Jan 08, 2018 05:09 PM
No new posts VW Volkswagen & Baja Bug General Discussion Considering buying a Baja Bug, but I have questions 4 AutomotiveDino 3323 Considering buying a B...
 Mon Jun 19, 2017 09:39 AM
daelan37 View latest post
