Latest: kevinbaja68
Overall: 3591
Visitors: 88
Total: 88
14: Pictures
16: Pictures
20: Pictures
21: Pictures
25: Pictures
27: Home
32: Home
53: Event Calendar
55: Pictures
64: Event Calendar
65: Pictures
82: Pictures
84: Event Calendar
86: Home
87: Home
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- ground clearence?
ground clearence?
madman74
madman74
Post Post subject: ground clearence?
Posted: Sun Oct 08, 2006 11:24 PM
Hi I was wondering what kind of ground clearences you guys are getting with your bajas? I measured mine from the front of the pan to the ground and the rear of the pan just befor the torsion housing. I found that I have 12.5 in front with 235/75/15s and 13" in the rear with 31/10.5s. Is this pretty normal it looks to be sitting a little low. Since the engine and trans sit about 2.5" higher in my baja than most others, i guess that means that is how much lower the rear body is going to sit compared to most.
Thanks
Shawn
Post Post subject: Re: ground clearence?
Posted: Sun Oct 08, 2006 11:47 PM
if the center of your wheels sit at or just below the floor pan you are about the correct level. this is just a guid but seems to work.
so you ground clarance will be about half the hight of yor tires.
Say10
Say10
Posted: Sun Oct 08, 2006 11:52 PM
Thats about how much clearance I have running 235/75r15s in the rear and 205/75r15s on the front.
Posted: Mon Oct 09, 2006 12:40 AM
I havent checked mine but right know the suspention is stock w/ 235s on front and 31s on the rear(i may start the lifting process next week)
cactusdog
cactusdog
Posted: Fri Oct 27, 2006 08:33 AM
Mine is shepard hieghth,fond that out two weeks ago.
