Visitors: 111
Total: 111
14: Pictures
15: My Account
31: Pictures
43: Pictures
47: Event Calendar
50: Pictures
53: Event Calendar
72: Event Calendar
78: Pictures
81: Event Calendar
95: Event Calendar
102: Pictures
1 2 3 ... 84 85 86 ... 103 104 105
Posted: Fri Jul 06, 2012 04:11 PM
Painted Rust Restorer on bottom of floor pans and rear skid plate. Neat stuff.
Re-installed skid plate. General "once over" before trip to the OBX.
Posted: Fri Jul 06, 2012 06:39 PM
Primered the fenders.
Tail lights are disassembled ready to cleanup and hopefully make work better.
Looking at it, I just have to cleanup the wheel wells and shoot a little flat black in there before putting back together. lol
Posted: Fri Jul 06, 2012 11:40 PM
Have my new tail lights bolted to the cage and new wires solder in. Need to put it all in a wire loom. Should have the electrical distrabution box wired in and the tail lights working reals soon.
Next is to wire in the electric fan and make sure it is all good. Last is plumb the radiator and Bleed Brakes.
ACE Hardware has made a killing off me on all the Nuts, Bolts, Wahsers and screws I have purchased over the last few weeks.
Talk about anal. I used my electric level to make sure all the tail lighs were perfect 90' to the ground and face back. every thing is in 1' or less. No more eyeballing it here.
Pointvirus
Pointvirus
Posted: Sat Jul 07, 2012 07:53 AM
Checked to see if my bug made it through the fire! crazy! 1200 acre fire burned kinda sorta in the yard next to where I have my baja parked! Thank God it missed. Still a pretty bad fire though.
cdfdata.fire.ca.gov/in...ent_id=651
Posted: Sat Jul 07, 2012 05:43 PM
3rd gear in my transmission was non existent so out came the engine and the trans this morning. Off to the transmission guy for a look.
I still have lots to do so it is only a mild setback.
Posted: Sun Jul 08, 2012 03:48 PM
Going to attempt to install my primered fenders. Had to do some trimming to clear the bars at the bottom of the doors. I don't know what they were drilled out for, but it wasn't a 66 vw. Smile So I also need to make some new holes and figure out how to install the bead stuff I had bought a long time ago as there are no holes in it.
Posted: Sun Jul 08, 2012 03:56 PM
Finished welding on the rear of the roll bar shock mounts just need to get some bungs for the bolts now.
Posted: Sun Jul 08, 2012 09:19 PM
Changed out my alternator. Found out it wasn't charging at all.
Dropped off my transmission to have third gear looked at.
Posted: Sun Jul 08, 2012 09:36 PM
Fenders installed. Smile
Ejbbal21
Ejbbal21
Posted: Mon Jul 09, 2012 06:05 AM
This last week I order a Saco rack from Darrel at Bugzyla and I also ordered hime joint kits for some custom tie rods. This is going to be a fun week of fabing on the baja.
Posted: Wed Jul 11, 2012 04:59 AM
Tried to adjust the brakes, still not much Sad looks like I have to pull the pedals back out and switch the brake pedal out for the one that was in it before.
Posted: Thu Jul 12, 2012 12:10 AM
Straightened (this must have been why it was converted to a baja after a wreck) the bent up brackets of my tailight bucket, sanded both of them and put a coat of primer on.
Now to order lenses and hopefully gaskets or seals. I still need to clean the electronic components and where the contact points are, but they are getting closer to being hopefully more reliable. I'm still looking at installing a wiring harness for a trailer and lights from a kit so I can hookup and go and also use them for more visibility/reliability.
Hyperwrx
Hyperwrx
Posted: Thu Jul 12, 2012 02:04 AM
Jeremy and I went and picked up my 3x3 setup and a set of Sway-a-way 12" coil overs in Las Vegas.
Posted: Thu Jul 12, 2012 06:54 AM
Just ordered my Window Seals and Tail light lenses from Chirco. Smile
Seals
Lenses
Smile
Posted: Sat Jul 14, 2012 05:16 AM
Alright! I already received them! Smile
5 Admin_AzBaja 7373 Baja Bugs on Wiki need...
285 MusicManiac 246559 Re: Baja sightings
No new posts VW Volkswagen & Baja Bug General Discussion FREE VW BAJA'S 0 azdesertrat87 488 FREE VW BAJA'S
No new posts VW Volkswagen & Baja Bug General Discussion Had to go play in the rain today! 3 azdesertrat87 1634 Re: Had to go play in ...
