AzBaja.com, Home of the VW Baja Bug Chirco.com
Toggle Content Chirco.com
Latest: craig0622
Overall: 2266
Members: 1
Visitors: 5
Total: 6
 Members:
01: kyle_pc_75 > Baja Forums
01: Amazon
02: Amazon
03: My Account
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Suspension, Brakes, Wheels and Tires -:- rear shocks
Store
VW Books For Sale
rear shocks
1audiman
1audiman
Post Post subject: rear shocks
Posted: Sat May 05, 2007 12:04 PM
i have leaking coilover shocks the cheapy ones coil over shock adjust at bottom to 3 settings , i have an irs rearend up two splines and am wanting some replacement rear shocks what can you recommend had looked at kyb gas-a-just as i have these on the frontend but unsure if they will be ok on the rear due to the lift.
or what can you recommend .
thanks
june 1970 vw baja lhd excali import 1641 twin webers,bodylift,flip front,rollcage,keystone wheels
azhunter
azhunter
Post Post subject: Re: rear shocks
Posted: Sat May 05, 2007 08:47 PM
You can buy longer length shocks for the rear. KYB, KONI,Bilstein all make them.
1audiman
1audiman
Posted: Sat May 05, 2007 08:50 PM
do you have any part numbers , all the vw places over here only sell standard or shocks for lowered beetles.
its proving difficult to find longer ones..
1audiman
1audiman
Posted: Sat May 05, 2007 08:58 PM
do you know if t2 68-79 shocks fit the rear
kyb say kg5539 for t1 rear but the t2 ones are kg5530 gives 3" longer travel but will they fit an irs beetle rear end.
thanks for your help,j
azhunter
azhunter
Posted: Mon May 07, 2007 03:49 AM
Ok,,,not knowing application,,,irs or swing, yesr and such go to this link......
www.explorerprocomp.co.../72-91.pdf
scroll to the bottom and check the travel specs and such to find a set that will work for you. I have a set of sway away race runner coil overs and a set of the mx2's to double them up. good luck.
azhunter
azhunter
Posted: Tue May 08, 2007 12:25 AM
www.thesamba.com/vw/cl...?id=447097
azhunter
azhunter
Posted: Tue May 08, 2007 12:27 AM
www.thesamba.com/vw/cl...?id=445928
1audiman
1audiman
Posted: Fri May 11, 2007 11:15 PM
thanks for your help managed to get some kyb gas-a-justs over here that will work so i have been told .
thanks again,j
No new posts VW Suspension, Brakes, Wheels and Tires Cheep 4 lug rear brake how to 12 Mykul 2262 Re: Cheep 4 lug rear b...
 Wed Mar 19, 2008 09:13 PM
zx10r203 View latest post
No new posts I have something to sell WTB Wide Five Rear Wheels 2 bajaghia 161 WTB Wide Five Rear Whe...
 Tue Aug 24, 2010 03:19 PM
ocejo View latest post
No new posts VW Suspension, Brakes, Wheels and Tires Couple last questions before I replace rear suspension 3 Billy 306 Re: Couple last questi...
 Fri Aug 13, 2010 08:56 AM
No new posts VW Suspension, Brakes, Wheels and Tires Has anyone used this rear bushing kit?
Found on mamotorworks.com
11 Billy 460 Has anyone used this r...
 Mon May 10, 2010 12:37 AM
Billy View latest post
No new posts VW Suspension, Brakes, Wheels and Tires Rear Trailing Arm issues
Diagnosing extreme positive camber in a rear wheel (irs)
3 ChuckD 359 Rear Trailing Arm issu...
 Sat May 08, 2010 12:15 AM
DONT View latest post
You can download files in this forum
Toggle Content Baja Bugs and Buggies
Toggle Content Store
show cart or checkout0 items
Cart Value: 0.00
We are not responsible for comments posted by our users, as they are the property of the poster.
