Visitors: 83
Total: 83
07: Garage
13: Event Calendar
15: Event Calendar
16: Pictures
28: My Account
30: My Account
45: Home
80: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Baja Questions, Getting in the loop!
The following users give thanks for this topic Anonymous - Fri Apr 10, 2009 01:15 PM
DutchBug
DutchBug
Post Post subject: Re: Baja Questions, Getting in the loop!
Posted: Fri May 16, 2008 08:05 PM
Why is link pin better than Ball joint?
I know the difference but don't understand why link pin is better.
Thanks for the info on 3x3 arms and such.
I read about it here but never dared to ask what it was Smile
Posted: Fri May 16, 2008 09:34 PM
Link pin is stronger than ball joint, and more versatile for things like improving suspension travel. You can't get much lift/travel out of a ball joint, but with LP, you have many more options. That's the way I understand it anyway.
Chrispy- Are you emissions exempt where you live? If not, I'd rethink getting an IRS car and instead get a '66 or older (that HAS linkpin already) and that way you're exempt from emissions as well. Just a thought. I think the consensus is that it's easier and cheaper to swap from swingaxle to IRS than from ball joint to link pin.
I've got some stock IRS trailing arms available CHEAP, btw. Stub axles are in them. I don't have the axles/CVs any more though. That'd get you converted cheaply and on the road, until the 3x3/930 CV/bus trans bug strikes you, which it will...
DutchBug
DutchBug
Posted: Fri May 16, 2008 09:48 PM
Okay, and is it possible to put the whole IRS, I mean including the torsion bars out of an IRS car to put into a swingarm car? So that no welding is required?
I have swing and want to put IRS thing in next winter.
And Chrispy, I have swing arms raised a bit (I don't know how much, bought it this way) with big wheels. Anyway ot drives terrible. On every bump or turn my rear feels like it is going it's own way. So my advice buy or build IRS.
Zoom153
Zoom153
Posted: Fri May 16, 2008 09:52 PM
No you need to cut the rear to include the torsion bar housing(basically everything behind the shifter coupling hole), or get an irs pan. You could probably find a way but it's much easier to get a pan that already has IRS
65 Type 11
chrispy56
chrispy56
Posted: Fri May 16, 2008 10:06 PM
california is exempt up to 75
Posted: Fri May 16, 2008 10:19 PM
You can use trailing arms, torsion bars, spring plates, and spring plate caps off of a donor car, but you will have to weld in the trailing arm pivots.
www.chircoestore.com/c...ts_id=1561
I am sure you can find a local welder to do it for you. It is easier to do w/the body off though.
BTW as far as ball joint vs. king/link pins....in stock form the ball joint is stronger and works well for most people. the aftermarket has huge support for the link pin style.
I think racers who prep their cars can get ~7-8 inches of travel w/ball joint. modified w/stock length trailing arms link pin can get ~8-9 inches. W/aftermarket trailing arms and coilovers you can get 12-14".
Obviously there is some coolness factor w/link pin style and aftermarket arms. But in reality if properly set up and maintained most people probably wouldn't be able to break a ball joint, unless big air is in it's future.
DutchBug
DutchBug
Posted: Sat May 17, 2008 12:27 AM
Thanks.
I have a kübel axl up front. It is pretty high but will this have more travel as well. I don't really go off road much, because there is not much off road here.
The kübel axl is great on the speedbumps we have about two every mile here in my town. I just need the back to be a little more speedbump proof.
It's kinda anoying. My front goes over over okay but the back kinda crashes into the bumps Sad
Anyway, I can get all the stuff from a dealer here and will weld it inthis winter.
Thanks again for the help.
Patzke
Patzke
Posted: Sat May 17, 2008 09:46 AM
Thank you!
Calling and hopefully going out to Phoenix to check them out tomorrow!
Patzke
Patzke
Posted: Sun May 18, 2008 09:38 AM
Had the engine off of the 71 for a few weeks, finally found time to cut the butt end off. looks fabulous. Smile
installed the new "Baja" exhaust and man, I did NOT expect that much noise... I LOVE IT. :)f
Patzke
Patzke
Posted: Mon May 26, 2008 11:09 PM
Thanks chrispy,
if anyone's looking at this thread anymore.
When cutting and turning, i have my torsion tube, basically the front end off my car. Shocks are off, steering box and arms are off, and being replaced with rack and pinion.
When cutting and turning is it absolutely necessary to remove the "leaves" or the springs inside? Can it be done without taking all the crap out?
"Baja bugs and buggies" says that it's possible.
Sounds like an easier approach, would you just take the extra hour and pull everything apart?
Posted: Tue May 27, 2008 05:12 PM
It can be done, but how much heat is being generated when welding? Inside the tube, I imagine it can get hot. Lots of grease inside the beam, could make it interesting. How much heat can spring steel take before losing it "spring" decription?
In other words, I would take it apart and clean it out. (provided I trusted my own welding to do it)
Patzke
Patzke
Posted: Tue May 27, 2008 09:37 PM
hahah yeah good point. Smile i'm having one of the senior welders here in the "airpark community" do it for me. Smile
He reccomended i take it all apart, and clean it out. Done did. Smile
Took but 45 minutes, do know why i questioned it....
5 Admin_AzBaja 8419 Baja Bugs on Wiki need...
1569 mufasavnvmc 1062169 Re: what did you do to...
 Sat May 11, 2019 07:20 PM
285 MusicManiac 256063 Re: Baja sightings
No new posts VW Volkswagen & Baja Bug General Discussion FREE VW BAJA'S 0 azdesertrat87 1262 FREE VW BAJA'S
0 Northmountainauto 2197 Shop Baja
