Visitors: 145
Total: 145
32: Event Calendar
45: Event Calendar
75: Event Calendar
79: Event Calendar
86: Pictures
102: Event Calendar
135: Event Calendar
143: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- fuel cell in back seat or alumspun up front?
fuel cell mounted in rear tray or spun aluminum under hood?
fuel cell behind seat on rear tray
31% 31% 31%
 31%  [ 7 ]
spun tank up front under hood
68% 68% 68%
 68%  [ 15 ]
Total Votes : 22
tigerextra
tigerextra
Post Post subject: fuel cell in back seat or alumspun up front?
Posted: Wed Oct 15, 2008 11:36 PM
$$limit is $200.
the question is:::
should one get a foam fuel cell and mount in the rear tray, theres no seat anyway. this option is more $$.
or
get a cheaper spun tank and mount up front.
thoughts to ponder among others are cost vs. benefit, long fuel lines with under hood option, idea of having fuel beind your seat, weight ratio with fuel up front, etc etc.
I enjoy every second of it!!
And a side note added,
all 6 of us agree!!
Post Post subject: Re: fuel cell in back seat or alumspun up front?
Posted: Thu Oct 16, 2008 12:31 AM
I'm happy with my aluminum tank up front, BUT I need a rear seat. I DO wish it was more than a 10-gallon tank though. Once I get things set up, I'll probably be keeping an eye out for a cheap way to increase my fuel capacity...
Posted: Thu Oct 16, 2008 12:33 AM
Oh- as for your poll, I'd say it's really hard to cast a vote, since you're the only one who knows your financial situation, AND how you intend to use the car.
That's my opinion, and for now I'm stickin' to it.
siacs
siacs
Posted: Thu Oct 16, 2008 01:34 AM
I had a spun aluminium tank installed in the back package tray area from P.O. I was not to keen on this. I just took it out last week as I am putting a whole new body on the pan and starting from scratch. I will not be locating the tank there this time. I will most likely using a stock tank in the stock location.
I will be selling the spun aluminium tank I guess
To each his own.....
tigerextra
tigerextra
Posted: Thu Oct 16, 2008 05:33 AM
yeah thats why i was thinking that if its inside, it has to be a foam cell, not spun tank, unless its under the hood, then it really doesnt matter.
ANOTHER UPDATE::: the other issue is that the spare tire will go wherever the tank doesnt. IE: with the tank under the hood the spare goes behind my seat ( a pain to get out i suppose), with the tank behind the seats, the spare tire will go up under the hood.
all 6 of us agree!!
Posted: Thu Oct 16, 2008 05:52 PM
I wanted a rear seat for the kids; and a cell in case I can race a Whiplash race or 2. Sooo, I bought a metal enclosed fuel cell and had it mounted in the front.
The downsides of the frt cell are: center of gravity goes up a little; handling will change a little depending on fuel level; spare will go on a roof rack or above the engine cage.
Upsides: have a back seat, which you did not need; gas is not in the passenger compartment... IMO safer; easier to service the tank/check the level etc; add weight to the front to help stability.
Posted: Sun Oct 19, 2008 06:24 AM
I have 2 tanks up front. stock 10gal and a 8 gal spun tank. I fact I like the car better when both tanks are full. makes the car ride better and helps in handling. I can get on it and still turn with out it getting to light in the front. when the car is empty and your on it hard you will not turn... and when it rains...The gas up front is a plus.
tigerextra
tigerextra
Posted: Mon Oct 20, 2008 08:01 PM
im starting to lean towards the idea of the tank up front. seems like there will be less worries with it there....that and i dont need to get a cell for it, just a spun tank./
all 6 of us agree!!
Posted: Tue Oct 21, 2008 06:48 AM
A 20 gallon fuel cell where the back seat is would be best for safety and handling. I like the T-2 tank in the rear luggage area. It puts the weight over the rear tires and handling is more like a rail. With out the tank up front highway handling suffers a bit. Having two tanks is nice if you spend a lot of miles off road away from gas stations.
siacs
siacs
Posted: Tue Oct 21, 2008 07:42 AM
Spun Tank For Sale
Let me know if you interested
tigerextra
tigerextra
Posted: Wed Oct 22, 2008 06:23 AM
got one!
all 6 of us agree!!
Neander
Neander
Posted: Wed Oct 22, 2008 11:31 PM
question, with a spun tank how do you gauge how much gas you have?
Posted: Thu Oct 23, 2008 12:57 AM
Have Bugzylla "customize" a sending unit to fit your tank.
Neander
Neander
Posted: Sat Oct 25, 2008 08:22 AM
haha ok then
Posted: Tue Oct 28, 2008 11:04 AM
Home Depot hands out custom fuel gauges in the paint department. About 1 foot long and 1 inch wide and FREE!!! ...work great...Too... Shocked
I run 2 tans one spun with no gauge and the stock with a sender. I run the upper spun tnak untell empty then flip to the lower stock tank and use the guage....
Or you can go old school and get a stick...
No new posts VW Volkswagen & Baja Bug General Discussion Lifting a super beetle front end 1 72sbbaja 2162 Re: Lifting a super be...
 Wed Jul 02, 2014 04:42 PM
Front End question
12 ButchW 7240 Re: What's the best wa...
 Sun Oct 27, 2013 04:42 AM
No new posts Club AzBaja (Arizona Chapter) bj front disk brakes with raised spindles 2 vwboat 3339 Re: bj front disk brak...
 Thu Dec 13, 2012 02:03 PM
No new posts Projects and Builds Possible rear seat?? 4 TattooedIrish 4211 Possible rear seat??
 Thu Aug 30, 2012 08:55 AM
Rigger View latest post
No new posts VW Volkswagen & Baja Bug General Discussion will a superbeetle back seat fit into a 68 bug? 3 jasonrc2008 1883 will a superbeetle bac...
 Tue Aug 28, 2012 11:11 PM
