Latest: bawward
Overall: 3614
Visitors: 264
Total: 264
22: Event Calendar
33: My Account
47: Event Calendar
55: Event Calendar
71: Pictures
87: Pictures
89: Pictures
90: Event Calendar
97: Pictures
101: Event Calendar
142: My Account
145: Event Calendar
150: Event Calendar
151: Event Calendar
158: Baja Forums
167: Drivers
168: Event Calendar
169: Event Calendar
170: Baja Forums
172: Baja Forums
176: Baja Forums
179: Baja Forums
181: Baja Forums
184: Event Calendar
188: Baja Forums
191: Baja Forums
192: Baja Forums
193: Event Calendar
194: Event Calendar
197: Event Calendar
198: AMAZON.com
202: AMAZON.com
203: Pictures
204: AMAZON.com
205: AMAZON.com
207: AMAZON.com
208: AMAZON.com
209: AMAZON.com
210: AMAZON.com
211: Baja Forums
212: Baja Forums
213: Baja Forums
214: AMAZON.com
218: AMAZON.com
219: AMAZON.com
220: AMAZON.com
221: AMAZON.com
222: Contact Admin
224: Baja Forums
225: AMAZON.com
226: AMAZON.com
227: AMAZON.com
229: AMAZON.com
230: AMAZON.com
231: AMAZON.com
232: AMAZON.com
233: AMAZON.com
234: Baja Forums
235: AMAZON.com
236: AMAZON.com
237: AMAZON.com
238: Baja Forums
239: AMAZON.com
240: Baja Forums
241: AMAZON.com
242: AMAZON.com
243: Baja Forums
244: AMAZON.com
245: Contact Admin
246: AMAZON.com
247: Event Calendar
248: Baja Forums
249: AMAZON.com
250: AMAZON.com
251: AMAZON.com
252: AMAZON.com
253: AMAZON.com
254: AMAZON.com
255: AMAZON.com
256: AMAZON.com
257: AMAZON.com
258: AMAZON.com
259: AMAZON.com
260: AMAZON.com
261: Baja Forums
262: AMAZON.com
263: AMAZON.com
264: AMAZON.com
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Question about the chirco baja build.
meangreen
meangreen
Post Post subject: Question about the chirco baja build.
Posted: Fri Oct 17, 2008 11:09 PM
i was lookn at the white bug build on chirco agin and i just caint seem to figure out what that damn foam is that they used to make the headliner,does anybody know what it is or where to get it ?
Post Post subject: Re: Question about the chirco baja build.
Posted: Sat Oct 18, 2008 12:11 AM
Call Don on Monday.
sandshark
sandshark
Posted: Sat Oct 18, 2008 01:34 AM
Sound deadening. Such a large, unreinforced (stiffened?) piece of sheet metal acts like a drum when introduced to vibration from the engine, tires or road surface. It just quiets the thing down.
Posted: Sat Oct 18, 2008 03:10 AM
Hhhmmm.
That got me thinking. Maybe I'll do the same before I put the headliner in.
Hopefully I'll have enough material from the padding kit I bought.
Wiggins
Wiggins
Posted: Sat Oct 18, 2008 04:23 PM
I bought that thin 1/4 inch foam from the fabric store. I think they use it for quilt making. I comes in rolls.
Stuff worked great for me.
General Manager
www.chirco.com
www.chircoestore.com
fast_1
fast_1
Posted: Sat Oct 18, 2008 08:35 PM
I really like this idea! Once I get my cage painted I may try and tackle it...
Anybody have any luck with sound deadening for the engine and transaxle? I'm considering Dynamat, it's on the pricey side though.
sandshark
sandshark
Posted: Sat Oct 18, 2008 11:20 PM
I hadn't heard of Dynamat 'till now fast_1. Thanks for the tip. I was going to use this stuff I have a roll of, that's similar to what I scraped out of the back of my Baja when I removed all of the original carpet, tarboard, etc. Didn't really want to use it. It's that crap that looks like foil on one side & recycled carpet on the other. So I googled Dynamat, and it ain't cheap at around $10 a square foot (Xtreme), but it sure looks like a better - & cleaner - way to go for the rear area over the transaxle and in front of the engine as well as the roof. The tech page says it insulates acoustically as well as thermally. Looks like a great solution to a problem that's really been buggin' me. Very Happy Very Happy Very Happy Guess I kinda mis-read what meangreen was askin' when he started this thead, ooops.
fast_1
fast_1
Posted: Sun Oct 19, 2008 10:16 PM
I think Dynamat is used a lot for cars with obnoxious stereos, but it seems like it would work for cutting down on engine/transaxle noise. I think what was used on the Chirco baja for the roof is probably a better idea for the roof. It's cheaper and hopefully easier to install, seems to look better to.
You guys think the foam would work with a rattle can adhesive? Although I could use it, don't wanna really invest in that right now. A compressor to run the spray gun would be helpful too, and perhaps an air ratchet, and an impact wrench... The list goes on and on. Crying or Very sad Someday.
Posted: Mon Oct 20, 2008 07:59 PM
Get the high quality spray adhesive and follow the directions and it will work. Buy the cheap stuff from Walle word and get poor results.
DesertDweller
DesertDweller
Posted: Mon Oct 20, 2008 08:25 PM
There is a company in Phoenix that makes a couple different sound deadening materials for automotive use. They are pricey, and I haven't used them yet, but have been researching and thinking about going this route for my baja before I put in a new headliner. Check them out...seems to be pro grade audio stuff.
www.secondskinaudio.com
Thuff
Thuff
Posted: Tue Oct 21, 2008 01:34 AM
On the last baja i built i used spray in foam from home Depot. To put it on i got a rubber glove and covered it with vasaline. In one had i sprayed the foam the other and I took the glove and spread the foam and kept it from going everywhere. It took a bit of practice but it worked ok. After it dryed I took a knife and sander and shaped it. Then i took it to the apolstry guy and had him put in the headliner. It made it a ton more quiet. I did the same kind of thing to the doors and pannels throughout.
Wiggins
Wiggins
Posted: Tue Oct 21, 2008 01:57 AM
Sorry
Just made me giggle a little.
General Manager
www.chirco.com
Thuff
Thuff
Posted: Tue Oct 21, 2008 02:04 AM
Ya it seemed a little funny to me too when i was trying it.
5 Admin_AzBaja 11676 Baja Bugs on Wiki need...
1569 mufasavnvmc 1196621 Re: what did you do to...
 Sat May 11, 2019 07:20 PM
285 MusicManiac 288402 Re: Baja sightings
103 SuburbanLegend 169423 Carbon Footprint...aka...
 Tue Sep 03, 2019 03:15 AM
Mykul View latest post
No new posts VW Volkswagen & Baja Bug General Discussion FREE VW BAJA'S 0 azdesertrat87 3597 FREE VW BAJA'S
