AzBaja.com, Home of the VW Baja Bug This Space for RENT!
Toggle Content Chirco.com
Latest: adamw444
New Yesterday: 2
Overall: 2217
Visitors: 31
Total: 31
02: Amazon
03: Amazon
04: Amazon
05: Amazon
06: Amazon
09: Amazon
10: Amazon
12: Amazon
14: My Account
15: Amazon
18: Amazon
20: Amazon
21: Amazon
22: Amazon
23: Home
24: Amazon
25: Amazon
26: Amazon
27: Amazon
29: Amazon
30: Amazon
31: Amazon
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Suspension, Brakes, Wheels and Tires -:- Cut and Turn or Adjusters??? help please
Store
VW Books For Sale
crazyfast
crazyfast
Post Post subject: Cut and Turn or Adjusters??? help please
Posted: Tue Nov 18, 2008 11:08 AM
Ok I did a search to find how to lift my front end cheaply and have struggled to find actual instructions. I've heard of this cut and turn but have failed to find any clear directions let alone pics on how to do this. I've also seen these adjusters Chirco sells but not sure how they work. I no longer have an easy access to a welder and no garage to work in. So my question is:
Being completely new to VW's... what is the EASIEST/fastest way to lift the front besides body lift and HOW???
This will be a daily driver that will be taken off road in the mountains and through the fields. Will be making a twin to the blue grass build. bluegrassghostinvestig...m/baja.htm
Thanks guys I appreciate any and all input.
Calling an illegal alien an “undocumented immigrant” is like calling a drug dealer an “unlicensed pharmacist\"
siacs
Colonel
Colonel
siacs
Post Post subject: Re: Cut and Turn or Adjusters??? help please
Posted: Tue Nov 18, 2008 12:47 PM
If I remember the book Baja Bugs and Buggies by Jeff Hibbard has info on this. My beam has been cut and turned and is a little stiff. Sometimes I wish I had the adjustable setup. Bugzyla and others will have more exact info I am sure.
Staff Officers
Posted: Tue Nov 18, 2008 03:20 PM
If you cut and turn or install adjusters you need to remove the front beam assembly and disassemble it completely. Then you will need to cut the center of the beam about and inch on either side of the center grub screw and either rotate it up 1/4 to 3/8 of an inch or replace that section that you cut out with an adjuster and weld it back in. The adjusters are only about $15 each so I would recomend the adjuster route.
Daryll AZ Baja P.R.
106 (O\!/O) VWs and counting since 1/2005 :mrgreen:
Real Integrity = doing whats right when nobody is looking.
crazyfast
crazyfast
Posted: Wed Nov 19, 2008 02:54 AM
Ok well now that makes sense now. Ya I think the adjusters sounds a bit easier, but hopefully it's as easy as it sounds lol. How long does it take to disassemble the front beam and reassemble? I think I read some where that you do this for people? I don't have easy access to a garage since I moved. Last I heard you where pretty busy.....
No new posts I have something to sell "Turn Key" Off-Road Kadron Carburetors
With 90-Day warranty and installation tech service
0 57baja 252 "Turn Key" Off-Road Ka...
 Fri May 14, 2010 08:30 AM
57baja View latest post
No new posts VW Body and Electric Problematic Turn Signals
Turn Signals when activated stay on. They dont blink.
11 shadowkidz 635 Problematic Turn Signa...
 Sat Apr 24, 2010 01:12 AM
shadowkidz View latest post
No new posts VW Suspension, Brakes, Wheels and Tires Newbie question - cut and turn 4 jmurphy166 309 Newbie question - cut ...
 Sun Apr 11, 2010 04:17 PM
catchbats View latest post
No new posts VW Racing I Need a motor or two, Long Blocks , turn key? 0 mickroo2 299 I Need a motor or two...
 Fri Feb 05, 2010 02:08 AM
mickroo2 View latest post
No new posts I have something to sell Link Pin beam, w/adjusters welded in.
beam
0 DONT 300 Link Pin beam, w/adjus...
 Sat Jan 16, 2010 05:10 PM
DONT View latest post
You can download files in this forum
Toggle Content Baja Bugs and Buggies
Toggle Content Store
show cart or checkout0 items
Cart Value: 0.00
We are not responsible for comments posted by our users, as they are the property of the poster.
