Chirco.com
AzBaja Site info
 Latest: adamw444
 New Yesterday: 2
 Overall: 2217
 Members: 1
 Visitors: 33
 Total: 34
Who Is Where: Members:01: siacs > Baja Forums
Visitors:01: Amazon
02: Amazon
03: Amazon
04: Amazon
05: Amazon
06: Amazon
07: Amazon
08: Amazon
11: Amazon
12: Amazon
13: Amazon
14: Amazon
15: Amazon
16: Amazon
17: Amazon
18: Amazon
19: Home
20: Amazon
21: Amazon
22: Amazon
24: Amazon
26: Amazon
27: Amazon
28: Amazon
29: Amazon
30: Amazon
31: Amazon
32: Amazon
33: Amazon
Staff Online:No staff members are online!
GPS
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Engines and Transaxles -:- Can I get an evaluation of the gear ratios I have chosen?
Users browsing this topic:
None
Author |
Message |
jon6.0
+2
Post subject: Can I get an evaluation of the gear ratios I have chosen?
Posted: Sun Feb 21, 2010 06:37 PM
Going to have Don throw a 5 rib together for me. I was thinking of going with the 3.78, 2.54, 1.48, .82 gears in it. Using 33" tires and the ring and pinion are 4.86. Engine is a 1776 w/ a single weber and 110 cam.
Weddle Sportman gear ratios:
2nd: 2.25, 2.36, 2.46, 2.54
3rd: 1.48, 1.58, 1.65, 1.70
4th: .82, 1.04, 1.13
Thoughts?
_________________ 1967 Baja
2005 GTO
2009 Speed Triple
+38
Post subject: Re: Can I get an evaluation of the gear ratios I have chosen
Posted: Mon Feb 22, 2010 06:23 PM
This would be my compromise for highway driving with 33" tires and 4.86 rp.
Weddle gears (assuming the 4.25 is still available)
4.25 first 2.54 second 1.48 third 1.13 fourth 54 mph @3000 rpms
72 mph @4000 rpms, 89 mph @5000rpms
It might be cheaper to use the 3 rib transaxle with 5.36 rp with 3.78 first, 2.06 second (both stock) 1.48 third and 1.09 forth 50 mph @3000 rpm
67 mph@4000 rpms, 84 mpg @5000
For strictly off road I would stay close ratio
with a 5.36 rp 3.78, 2.06, 1.58, 1.21 45mph@3000 rpm, 61 mph@4000
with 4.86rp 4.25, 2.54, 1.70, 1.30 47mph @3000 rpm, 62 mph @ 4000
A 1776 needs as much help as posible "motorvating" 33 inch tall tires on a Baja. The better the rpm range of the cam matches your driving speeds the better it will work. In one Baja I ran the w 130 cam in a 1776 with a stock geared 3 rib T-2 transaxle and 30" tall tires it was fun but below 15 mph in 1st gear and 25 in second there low speed finese did not exist. Being in the right gear all the time was a must. If you have not yet built the engine sleeve the lifter bores and use an Engle VZ 14 cam (FK 41 if your heads flow at the cams lifts), stroking it 76,78 or 82 mm will also help. Custom ported heads with small ports but high air velocity heads also help.
VW used both the 5.36 rp and shorter 14" tires to get the first bay buses moving with 50 hp.
Duplicating those overall tire/gear ratio aspects helps. From there closing them up and lowering them helps a lot.
jon6.0
+2
Posted: Mon Feb 22, 2010 06:50 PM
Don has a special right now on two 3 rib boxes for $700 and $750. Both with superdiffs and close ratio 3rd and 4th.
One is 3.78, 2.06, 1.48, 1.17
The other is 3.78, 2.06, 1.58, 1.22
Which one should I get? I'm leaning toward the one with the 1.17 4th gear as it's $50 cheaper and is the best compromise of onroad and offroad.
2005 GTO
2009 Speed Triple
jon6.0
+2
Posted: Mon Feb 22, 2010 07:14 PM
I told them to hold the one with the 1.17 4th gear for me.
2005 GTO
2009 Speed Triple
+38
Posted: Tue Feb 23, 2010 12:51 AM
You'll like the 1.17, the 1.30 fourth is a bit low for highway driving. Even if it was $50 more I would of bought thre one with the 1.17.
The 1.17 fourth gear nets 52 mph @3000 rpms and 69 mph @ 4000 rpms.
jon6.0
+2
Posted: Tue Feb 23, 2010 01:01 AM
On my way right now to drop it back off with Daryll. I'm working constantly until the offroad trip and the only way its going to get done is if I don't do it.
2005 GTO
2009 Speed Triple
You can download files in this forum
Baja Bugs and Buggies
Picture Box
Store
0 items Cart Value: 0.00
