Chirco.com
AzBaja Site info
 Latest: craig0622
 Overall: 2266
 Members: 1
 Visitors: 9
 Total: 10
Who Is Where: Members:01: jone$yyy > Baja Forums
Visitors:01: Amazon
02: Pictures
06: Home
Staff Online:No staff members are online!
GPS
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Body and Electric -:- What does this light mean?
Users browsing this topic:
None
Author |
Message |
McInnis
Post subject: What does this light mean?
Posted: Fri Jun 05, 2009 01:38 AM
The little light to the right of the turn signal light on a stock 64 speedo?
Came on after 10 minutes of driving and when I shut of the bug and when I turned it back on less then 5 minutes later it was off.
_________________ If it doesnt make it go faster, stop quicker, or stand out then its useless.
kyle_pc_75
Colonel
+6
Posted: Fri Jun 05, 2009 02:53 AM
Oil pressure. Make sure you find out why it came on! How's the level, got any bad leaks, etc.?
Kyle
_________________ '75 Baja Bug, lifted 2", mostly stock but fun!
Staff Officers
+27
Post subject: Re: What does this light mean?
Posted: Fri Jun 05, 2009 04:31 AM
If they are hooked up correctly, the green is alternator/generator, and the red is oil PSI.
_________________ Daryll AZ Baja P.R.
HOUSE FOR SALE www.610ash.com
106 (O\!/O) VWs and counting since 1/2005 :mrgreen:
Real Integrity = doing whats right when nobody is looking.
McInnis
Posted: Fri Jun 05, 2009 06:00 AM
I checked the oil and it all seemed ok, is there a change when I have an external oil cooler on where the oil level needs to be on the dipstick? And it was a green light, I don't know where the red light would be, I'll post up a pic later.
McInnis
Posted: Fri Jun 05, 2009 06:07 AM
And I fixed the major leak from the valve cover last week
Staff Officers
+27
Posted: Fri Jun 05, 2009 01:19 PM
The oil level in the crank case should be the same with or without a cooler/external filter, up to the second line is full. It just may take more oil to fill it to that point. If its a green light then it should be the charging light. Its usually the one on the right side of the turn signal indicator. The light on the left of it should be the red oil indicator, if its not hooked up that should be your next priority before even driving your car. It could save you a motor. Check to see if the light comes on when you turn the ignition on before you start it, and then it should go off once started.
McInnis
Posted: Fri Jun 05, 2009 04:11 PM
Nothing comes on when the key is in run but the engine is not on
| Topics |
Replies |
Author |
Views |
Last Post |
Projects and Builds
Finally Mounted The Light Bar
2 |
Hamm0ckjames |
104 |
Finally Mounted The Li... Mon Aug 23, 2010 11:20 PM az350x  |
VW Volkswagen & Baja Bug General Discussion
Fabbed new plate mount and light
9 |
Tcatdrv |
284 |
Fabbed new plate mount... Sun Jul 04, 2010 06:41 PM Tcatdrv  |
Does the stock speedometer have a light?
2 |
pschneider |
305 |
Re: Does the stock spe... Wed Jun 02, 2010 03:45 AM nukeworker  |
I have something to sell
old school ahoogaa horn,aluminum fuel tank,chrome tail light
2 |
baja62 |
321 |
Re: old school ahoogaa... Fri Nov 20, 2009 04:22 AM baja62  |
Need Opinions On Light Bar
Go to page:
1, 2, 3, 4 ]
50 |
57baja |
7611 |
Re: Need Opinions On L... Fri Aug 07, 2009 02:56 AM nukeworker  |
You can download files in this forum
Baja Bugs and Buggies
Picture Box
Store
0 items Cart Value: 0.00
