Toggle Content Chirco.com
Latest: adamw444
New Yesterday: 2
Overall: 2217
Visitors: 36
Total: 36
01: Amazon
02: Amazon
04: Amazon
06: Amazon
07: Amazon
08: Amazon
11: Amazon
12: Amazon
14: Amazon
15: Amazon
17: Amazon
18: Amazon
19: Amazon
20: Amazon
22: Amazon
23: Amazon
24: Amazon
25: My Account
28: Amazon
29: Pictures
30: Amazon
31: Pictures
32: Amazon
33: Amazon
34: Amazon
35: Home
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Engines and Transaxles -:- Crank Pulley Diameter?
Store
VW Books For Sale
Rickman
Rickman
Post Post subject: Crank Pulley Diameter?
Posted: Tue Jan 26, 2010 06:51 PM
Does anyone know what the diameter of a stock crank pulley is?
I have an aluminum degreed pulley on my 1600DP and I will measure it later when I get home. Not sure if it's a power pulley or not.
I want to get a spare belt and I want to make sure I get the correct one.
Post Post subject: Re: Crank Pulley Diameter?
Posted: Tue Jan 26, 2010 10:37 PM
Power pulley inner diameter is 5 and 1/4 " and the stock should be 5 and 3/4". Stock belt Conti 9.5X905 OR 7350 Gates Power Pulley Belt Conti 9.5X850 OR 7330 Gates. The Gates 7350 outlasts the fabric woven Conti 9.5x905 ten to one.
Rickman
Rickman
Posted: Thu Jan 28, 2010 03:02 AM
I measured the outside diameter of my pulley and it is 6 3/4". I did find a number on the belt that is currently installed:
11.3 X 912 and I guess the belt PN: 9730798
Posted: Thu Jan 28, 2010 03:35 AM
If you measure the inside diameter you will find it is a stock size pulley.
Rickman
Rickman
Posted: Thu Jan 28, 2010 01:50 PM
That's good to know. I didn't want the smaller power pulley. I read that the power savings wasn't worth the reduction in cooling. I don't plan on seeing if I can go faster, I want reliability. Thanks.
Posted: Thu Jan 28, 2010 04:03 PM
Good idea keeping the stock pulley. Another good idea is keeping a spare belt, alt cable and clutch cable with you.
You would switch to a power pulley when you start consistantly running over 4000 rpms to bring the fan speed back to normal. Now go do something with that air filter.
Rickman
Rickman
Posted: Thu Jan 28, 2010 06:30 PM
Are the K&N Pre-Filters any good? Saw them on the K&N website.
Uni Filters? Where to see/buy?
Posted: Thu Jan 28, 2010 10:53 PM
You have a K&N one it. If the cotton is still in it is is ok. Uni Filters are 1/2 thick foam air filters. Karls has the Uni Filters. I like to use one oiled Uni Filter one over the K&N and one more none oiled Uni Filter over the oiled Uni Filter.
Rickman
Rickman
Posted: Fri Jan 29, 2010 12:26 AM
I'll have to drop by Karl's and see if they have my size.
Posted: Fri Jan 29, 2010 02:28 AM
If not www.unifilter.com.
No new posts VW Suspension, Brakes, Wheels and Tires Largest diameter tire a stock fendered bug can run? 4 DittyDuane 454 Re: Largest diameter t...
 Fri Apr 30, 2010 05:57 AM
DittyDuane View latest post
No new posts VW Engines and Transaxles oil leak from behind timing pulley 13 Blake22211 696 Re: oil leak from behi...
 Fri Apr 30, 2010 05:33 AM
Baja_Blue View latest post
No new posts VW Engines and Transaxles Blow By/crank case pressure 10 TrailRail2110 478 Blow By/crank case pre...
 Sat Feb 13, 2010 06:41 PM
TrailRail2110 View latest post
No new posts New Members crank pulley
motor parts
0 caversmoon 355 crank pulley
 Fri Oct 16, 2009 02:56 PM
caversmoon View latest post
No new posts I have something to sell T-1 crank and rods $30.00 0 perrib 297 T-1 crank and rods $30...
 Tue Oct 06, 2009 04:46 PM
You can download files in this forum
Toggle Content Baja Bugs and Buggies
Toggle Content Store
show cart or checkout0 items
Cart Value: 0.00
We are not responsible for comments posted by our users, as they are the property of the poster.
