Chirco.com
AzBaja Site info
 Latest: adamw444
 New Yesterday: 2
 Overall: 2217
 Visitors: 28
 Total: 28
Who Is Where: Visitors:01: Amazon
03: Amazon
04: Amazon
05: Amazon
06: Amazon
07: Amazon
08: Amazon
10: Home
11: Amazon
12: Amazon
13: Amazon
14: Amazon
16: Amazon
17: Amazon
19: Amazon
20: Amazon
21: Amazon
22: Amazon
23: Amazon
24: Amazon
25: Amazon
26: Amazon
27: Amazon
28: Amazon
Staff Online:No staff members are online!
GPS
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- Tech, Tips, Things to know. -:- front beam inner bearings
Users browsing this topic:
None
Author |
Message |
1969Type1BAJA
+1
Post subject: front beam inner bearings
Posted: Sun Mar 07, 2010 02:44 AM
Measure the EXACT inside dimension of your beam without the bearings. Get a big fat washer at the hardware store that's slightly larger than that. Also get a piece of all-thread, three nuts, and some washers that will fit inside the big washer. Grind two flat spots off of opposing sides of the washers so it has two flat edges and two round edges. Grind the round edges to match the ID of the beam exactly. If you did it right, you'll be able to barely fit the washer in the end of the torsion tube, and you'll have two gaps, one on either side, as you look at it inside. Put the all-thread inside of the modified washer with a nut and washer on each side of it loosely. As you push the large washer down into the torsion tube, it will tip on its axis and clear the bearing. Once it has cleared, you can pull it back and it will fit nice and snug on the back side of the bearing. Put a scrap piece of steel (or wood, whatever...) with a hole in it up against the face of the torsion tube with the all-thread poking through it. Now you can use that third nut and washer to tighten up on the wood block, or steel block, which will cause the large washer inside to pull the bearing out like a puller. Likewise, when you get it to the end of the torsion tube, if you can't get it out, you can slide a metal pipe down the all thread and bang on it like pulling dents with a slide hammer.
POST FROM 57BAJA thanks for the tips
| Topics |
Replies |
Author |
Views |
Last Post |
I have something to sell
Thing beam, spindles, arms. $300
7 |
BugZyla.com |
377 |
Re: Thing beam, spindl... Fri Jul 23, 2010 11:15 PM BugZyla.com  |
B/J beam D-D, swing axle trans
2 |
BUILTnotBOUGHT |
106 |
B/J beam D-D, swing ax... Tue Jul 13, 2010 12:56 AM BUILTnotBOUGHT  |
VW Suspension, Brakes, Wheels and Tires
Calculating width in front and back
4 |
JVAZ |
190 |
Re: Calculating width ... Wed Jun 30, 2010 10:28 PM JVAZ  |
VW Volkswagen & Baja Bug General Discussion
front tires on a rail
1 |
Vipon |
120 |
Re: front tires on a r... Wed Jun 16, 2010 01:51 AM perrib  |
NEW 5 over coilover conversion beam $200, regular price $285
0 |
BugZyla.com |
200 |
NEW 5 over coilover co... Tue Jun 15, 2010 06:39 PM BugZyla.com  |
You can download files in this forum
Baja Bugs and Buggies
Picture Box
Store
0 items Cart Value: 0.00
