Latest: rcwtony
Overall: 3607
Visitors: 100
Total: 100
19: Event Calendar
26: Event Calendar
35: Contact Admin
36: Pictures
59: Event Calendar
69: My Account
71: Pictures
90: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- bus transaxles?
bus transaxles?
weddlebaja
weddlebaja
Post Post subject: bus transaxles?
Posted: Fri Mar 19, 2010 04:48 AM
why is it better to put in a type 2 bus transaxle in your baja? would it give you more power? what about speed? can anyone help me?!?
Billy
Billy
Posted: Fri Mar 19, 2010 05:06 AM
Im actually in the process of putting one in. I can't spit out any numbers at the moment but the gearing is lower giving more torque and the bus transmission is just generally stronger and beefier than the bug one. If you can go that route, it's a good way to go. I will try to find one of my charts that has a breakdown of the gearing by transmission type.
donsbusbox
Brigadier General
Brigadier General
donsbusbox
Posted: Fri Mar 19, 2010 05:16 AM
BUG Trans use the same gearset (1st thru 4th) as the 3 rib and 5 rib BUS however they only have a 6" ring gear (the weak link). The BUS Trans is preferred because it has a 8" ring gear AND lower ring and pinions. Bug trans used 4.37, 4.13 and 3.88 ratios while the 3 rib has a 5.38 and the 5 rib a 4.86. The 091 uses a 4.57 and everything is biggger inside. VW kept the gear ratios the same but made higher ring and pinions as they added power over the years.
More here: www.donsbusbox.com/what_trans.html
Don\'s Bus Box\r\nVW Trans Specialists\r\n602-670-0192
DutchBug
DutchBug
Posted: Fri Mar 19, 2010 12:39 PM
and here: www.thesamba.com/vw/fo...p?t=143138
Billy
Billy
Posted: Fri Mar 19, 2010 11:56 PM
Good stuff
longenterprises.com/te...lstuff.htm
Where I got most the info about my 091. Very helpful for any bus related stuff
www.ratwell.com/techni...saxle.html
