Latest: rcwtony
Overall: 3607
Visitors: 143
Total: 143
08: Event Calendar
39: Event Calendar
59: Home
108: Event Calendar
118: Home
125: Pictures
136: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Line X
Line X
JVAZ
JVAZ
Post Post subject: Line X
Posted: Mon Aug 09, 2010 10:06 PM
I have my pan stripped down and am planning to get it covered with Line X. When covering a pan with a product like that, which is a little thicker, is there anything that needs to be taped off so that certain things will fit back on properly?
Thanks for any help.
kyle_pc_75
kyle_pc_75
Posted: Tue Aug 10, 2010 12:37 AM
Hmmm...basically all the mounting points. The lips of the pan, the front where the beam bolts on, the two bolt points on the shock towers, the top of the napolean hat, and the rear edge of the floor pans. Also maybe where components mount like the brake master cylinder.
Kyle
Posted: Tue Aug 10, 2010 03:06 PM
IN addition to Kyle's list, the shifter opening, pedal mount opening and all seat belt mounting holes.
Post Post subject: Re: Line X
Posted: Tue Aug 10, 2010 04:06 PM
And anything with threads.
JVAZ
JVAZ
Posted: Wed Aug 11, 2010 07:29 PM
Thanks guys. I spoke to someone at a Line X facility and he said they block out the threaded holes and tape of the seat rails, but everything else, like areas where the body sits on the pan, they just don't put it on as thick so everything still fits together.
Does that sound right to you guys? I guess they've done it before, but I just want to be sure because I'm guessing once they put it on, it's tough to get off.
No new posts VW Volkswagen & Baja Bug General Discussion got a line on thing suspension parts... 1 kyle_pc_75 2515 got a line on thing su...
 Tue Sep 01, 2009 02:35 AM
57baja View latest post
No new posts VW Volkswagen & Baja Bug General Discussion main fuel line leak... 6 Kev_n_AZ 3982 Re: main fuel line lea...
 Fri Dec 05, 2008 03:25 PM
Kev_n_AZ View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Bajawarrior Back On-Line!!! 7 bajawarrior 2873 Re: Bajawarrior Back O...
 Thu Mar 27, 2008 05:27 PM
fatalifeaten View latest post
No new posts VW Volkswagen & Baja Bug General Discussion fuel line 2 cperry2704 1321 Re: fuel line
 Tue Dec 18, 2007 03:44 AM
No new posts VW Volkswagen & Baja Bug General Discussion Solid Fuel Line Question 6 r8rfan66 2642 Re: Solid Fuel Line Qu...
 Mon Sep 03, 2007 06:58 PM
