Latest: Curtis
Overall: 3613
Visitors: 121
Total: 121
03: Event Calendar
13: Event Calendar
18: Event Calendar
26: Event Calendar
27: Event Calendar
59: Event Calendar
79: Event Calendar
86: Event Calendar
89: Event Calendar
97: Event Calendar
121: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Shock Hoops
Shock Hoops
Post Post subject: Shock Hoops
Posted: Mon Jun 06, 2011 02:11 AM
Im looking into different ways to mount my shocks on the Moldy Japelino.
I trying to do so without having to cut holes in the body or fender wells.
My idea was to run hoops from the end of the horn to the top of the shock tower extending all the way up to the top of the fender wells.
Just wondering if anyone has ideas on this fabrication or any other ideas Question Shocked
What can one DO......
Posted: Mon Jun 06, 2011 03:15 PM
search for "project ernest" Daryll put dual rear shocks on it without cutting it up.
Ejbbal21
Ejbbal21
Post Post subject: Re: Shock Hoops
Posted: Wed Jul 20, 2011 05:50 PM
If your are still looking ideas here Is my build thread on another site. www.shoptalkforums.com...8&t=136525
It's what I had on my baja for 20 years. I put a Bugzyla lift on and I'm refabing to use the extra 3"
Posted: Wed Jul 20, 2011 10:42 PM
What we did on the Ernest project was run a piece of 1.5" tubing from side to side just behind the back seat area, and welded 1/2 nuts inside of it for the shock mounts. This does require hole sawing a 1.5" hole in each side of the fender well. We then took a 4" square plate and hole sawed the 1.5 hole in and and welded that to the fender well area and the tube running through the body. We also attached the tube running through the body to the rear bumper mounts that came through the firewall with 4 bolt plates and a piece of tubing. Killed 2 birds with one stone.
Grunt-0341
Grunt-0341
Posted: Sat Jul 23, 2011 03:33 AM
Pics Daryll?
Grunt-0341
81mm Mortar Man
1st Battalion 6thMarines
1985 - 1989
Semper Fi
Rom 1:16
www.infowars.com
www.oathkeepers.org
thepatriots.us/
Grunt-0341
Grunt-0341
Posted: Sat Jul 23, 2011 03:35 AM
Bug looks great, also cute kid Smile
Grunt-0341
81mm Mortar Man
1985 - 1989
Semper Fi
Rom 1:16
www.infowars.com
www.oathkeepers.org
thepatriots.us/
Posted: Sat Nov 12, 2011 07:39 AM
I cant wait to get back on the moldy japerlino !!!
Uploaded with ImageShack.us
Sittin around today.....heres the idea
Using a peice of round from the bumper stop to the upper well five bolts the fender.
Using the suicide wheel im goin to custom fit the round stock to have a slip fit over the top of the bumper stop.
The top will be capped with a nut welded to the inside and the two bosses will have the same geometry as the stock tower........just extend to the top of the well.
The cap on the tower extention will be use to tie the two towers with a truss bar inside and behind the rear seat.
The existing shock bolt mount will be used for a truss bar aswell over the top of the 002 trans on a 10* pacific custom mount which gives plenty of room between the trans and the luggage well.
An extra piece of round will tie the shock extension half way up to the small gap midway up my frame horn where i plan on mounting a bracket with the extension support to mount up a rear swaybar.
Im thinking that this should tie everything together nicely with only a small hole drilled for the truss bar behind the seat.
Posted: Wed Jan 11, 2012 08:57 AM
Well
I scrapped this idea yesterday.
Goin to shorten a cage for the mounts cause what i want to use for shocks has too much TRavEL.
And running with twins made it just a touch worse for room.
Itll seal!!!!
allisontech
allisontech
Posted: Thu Jan 19, 2012 03:31 AM
Did this end up working for you? I'm trying to figure out what path to take on our rear shocks.
Posted: Thu Jan 19, 2012 09:56 AM
I scrapped the IDEA.
Arent you running just 1 in. longer on your build or did you go 3x3 or longer????
My moldy japelino (MJ) is going to be running 3x3 with bus shocks for now.
My cow was running stock trailers with a mess of a build. Torsions are turned way too high for any ride and are on the edge of a BUST.
As far as a mount goes
I opened up my wells
Bent some pipe
Measured and trimmed for heat
Measures the angle for the taller travel
And Ill box the well later.
IM GOIN TO BASE THE JAPELINO off my COW.
Running heater boxes etc.
The only difference between the two will be the shocks and trailing arms.
Im going to work on the same mount base being the same off both coming off the torsion housing and the horn.....just the japelino is going to build a tower off the cow for the taller travel.
Always remember your TA pivot angle.
allisontech
allisontech
Posted: Thu Jan 19, 2012 12:28 PM
Thanks for the pics, I ended up going just 1" longer. But I also have to really crank the rear torsions quite a bit to try and match the 3" raised front spindles. Hopefully the new torsions will settle a little after the car is driven. Takes two people to compress them far enough to get the plates off the stops without the engine and body installed.
Posted: Thu Jan 19, 2012 05:22 PM
You could always notch the plates on the bottom.
If youre running with SAW Heavy Duty they are wider than stock.
I ground down the the stop on the torsion housing to bring the axle to about 14 degrees.
With running T2 CVs ill notch the plates after my 29mm torsion bars have taken a set and need indexing.
Im thinking the picture of my boy Jake is after the grind on the stop.
Yep those pics with the new plates are after the grinding of the stop......you can sure see the difference from the stock plates from the hole in the cast tower in that last pic on July 23.
Posted: Sat Jan 21, 2012 09:11 AM
Heres an overhead drawing of the web im thinking about right under the luggage conpartment. Thinking on running the members more with the trailing arm and pivot then with the plates.
That way i dont have to play with angling my bosses to try matching the pivot.
The angle of the supporting member leaves all the drilling square and offsets the shocks for a touch FATTER look from the back.
I might run a fourth member if i can pipe it under.
And between my heat and my drive.
Posted: Sat Jan 21, 2012 09:16 AM
Posted: Sun Jan 22, 2012 01:01 AM
Looks to me that 10 degrees is going to be my
MAGIC Number
15 onthefarm 12807 Number on the shock to...
 Sat Jul 28, 2012 05:03 AM
No new posts VW Volkswagen & Baja Bug General Discussion shock setup 5 thext94 5502 Re: shock setup
 Wed Apr 14, 2010 02:16 PM
No new posts VW Volkswagen & Baja Bug General Discussion I need a rear shock 0 perrib 1815 I need a rear shock
 Sat Jul 18, 2009 05:44 AM
No new posts VW Volkswagen & Baja Bug General Discussion Shock Towers new picks!
30 DRUMMOND 42453 Re: Shock Towers new p...
 Tue Sep 23, 2008 11:05 AM
No new posts VW Volkswagen & Baja Bug General Discussion Wet Suit Shock Barriers 3 57baja 3328 Re: Wet Suit Shock Bar...
 Wed Jun 18, 2008 07:21 AM
WaBaja View latest post
