Visitors: 111
Total: 111
04: Home
25: My Account
30: Pictures
32: Event Calendar
38: Event Calendar
60: Event Calendar
111: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- dellorto 36 center mount
_-Mad-Max-_
_-Mad-Max-_
Post Post subject: dellorto 36 center mount
Posted: Tue Jun 19, 2012 09:59 AM
Ok here's the deal I'm trading a guy my stock solex and $100 cash for a dellorto 36 drla complete for center mount with intake. I a wondering if I wil have any problems with it and my stock 1600? My motor has a 009 with electronic ignition. And also how hard is it to tune the carb.
im in need of a new front clip for my 74 ghia, i dont care what year its from but i need one in order to fix my front end, can anyone help out?
TINMAN
TINMAN
Post Post subject: Re: dellorto 36 center mount
Posted: Tue Jun 19, 2012 03:17 PM
I have a single 40 weber on my 66 it runs great use the heat risers and be prepared to spend a few buck s jetting it .you will have a flat spot but the power is nice . my motor is a 1600 with a web 163 cam and header.
TRUMP 2020
Posted: Tue Jun 19, 2012 03:38 PM
Should be a good deal as long as it still has functional preheat and a good throttle shaft. You might want to pull the top off and see if it is water damaged.
No new posts VW Volkswagen & Baja Bug General Discussion Center Mount Fan Shroud 4 Darn_Near 3207 Center Mount Fan Shrou...
 Sat Apr 12, 2014 05:13 AM
ghettodish View latest post
No new posts VW Volkswagen & Baja Bug General Discussion best way to mount a light bar or roof rack? 7 woodin 13078 best way to mount a li...
 Mon Feb 07, 2011 02:31 AM
woodin View latest post
No new posts VW Volkswagen & Baja Bug General Discussion dellorto parts in united states 1 adamw444 1408 Re: dellorto parts in ...
 Fri Jul 30, 2010 03:23 PM
No new posts VW Volkswagen & Baja Bug General Discussion Fabbed new plate mount and light 9 Tcatdrv 4175 Fabbed new plate mount...
 Sun Jul 04, 2010 07:41 PM
Tcatdrv View latest post
No new posts VW Volkswagen & Baja Bug General Discussion cut the center beam 1 1969Type1BAJA 1720 Re: cut the center bea...
 Sun Dec 06, 2009 08:33 PM
