Visitors: 93
Total: 93
14: My Account
39: Pictures
53: My Account
60: Event Calendar
64: Contact Admin
67: Event Calendar
72: My Account
76: Home
80: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Rack and Pinion setup on a Baja bug
DFWbaja
DFWbaja
Post Post subject: Rack and Pinion setup on a Baja bug
Posted: Wed Jan 28, 2015 11:36 PM
I have a 1969 Baja bug. It has a Ball joint to link pin converted front beam that is 6 inches wider than stock. I also have a 6 inch beam extender. I need to put a rack and pinion on this setup. Looking for suggestions on what I need. I know I need the Rack mount the rack and tie rods of the correct length. I also will need an elbow link and possibly a different steering shaft. I have the stock one still.
How do you experts set this up?
Kreed
Kreed
Posted: Thu Jan 29, 2015 02:16 PM
I just posted some pictures for you on my thread in project builds. I needed to weld a plate to the bottom of the adpter bracket to raise it a little bit. Also I needed to raise the rear of the gas tank slightly to clear the steering shaft. I used some left over body gasket and folded it over once or twice to get the clearance needed.
Pictures:
Posted: Fri Jan 30, 2015 02:41 PM
I used a stock Ford Bronco 1990 for $40 ... it is 3 1/2 turns "lock to lock" I ran it without power steering and it was much better than a stock VW steering box. I have done 5 so far and none of them have ever broke 4 of them were center mounted and one side mounted... A rack unit is 2 to 2 1/4 turns lock to lock and with out power steering it a bear off road..
Posted: Fri Jan 30, 2015 02:44 PM
click my link to see more on how I did it... I think I have about $160.00 invested in making it work.
5 Admin_AzBaja 7353 Baja Bugs on Wiki need...
1568 mufasavnvmc 1020884 Re: what did you do to...
285 MusicManiac 246489 Re: Baja sightings
No new posts VW Volkswagen & Baja Bug General Discussion FREE VW BAJA'S 0 azdesertrat87 478 FREE VW BAJA'S
0 Northmountainauto 1783 Shop Baja
